Go Back   Lateral-g Forums > Vendor Specific Technical Discussions and Support > Supporting Vendor Group Purchases
Old 08-16-2005, 04:47 PM
Todds69's Avatar
Todds69 Todds69 is offline
I'm Jones'n for some lights? Help Me! Any word yet?
Old 08-17-2005, 02:10 PM
Fluid Power's Avatar
Default Me Too
What's up?
Darren
Old 08-17-2005, 02:39 PM
camcojb camcojb is online now
I'm not trying to keep secrets but I hate posting that such and such will be done in a week or whatever. And then get disappointed when it isn't.
I can say the front 69 lights are done, just have to pick them up locally so by Friday we will be shipping them again. For the rest of August we will be offering 10% off on the front lights as a thanks for your patience.
And the 67/8 taillight is also supposed to be machined by today. Now this is just one set to get firm pricing on the machining, but we have 50 sets on order immediately assuming the pricing will work. They require a LOT more machining than the 69's. I will post pics and pricing as soon as I have them.
Old 09-08-2005, 06:33 AM
evilzee28 evilzee28 is offline
Hi Jody, is it possible to driving/fog lights to the front turn signal lights? Maybe using some "projector" lights or something,which look about the right size, you know, use the housing & fit the lamps to it, or are they machined as one piece? I'm gonna run with RS hideaways, but without all of the mechanism to open them ie fixed closed & thought this might be a way of getting extra light at the front on those dark old nights. Turn signals would be fitted elsewhere, thanks
Old 09-08-2005, 06:49 AM
The bulbs we use start life as fog/driving lights. So with a different rear bracket they would work fine, the billet surround is set up for the bulb. We initially wanted to keep them as driving lights with some amber led's built in for the turn signals, but you couldn't see the turn signals with the driving lights on. Only issue would be getting Pascual to make the bracket, he's a very busy guy!
Old 09-08-2005, 07:11 AM
XcYZ's Avatar
XcYZ XcYZ is offline
I'll be posting some new pictures of the front marker lights tonight.
My LS7 69 Camaro
Old 09-08-2005, 07:37 AM
thanks for that Jody, I could probably fabricate the brackets myself if he's too busy, would there be any means of adjusting the beam on the light for height , direction etc?
Old 09-08-2005, 08:30 AM
The brackets we had could be adjusted for height. You could shim them for direction. We have those old brackets, but the bulb used for them is no longer available. So we found a new light to fit the housing and since 99% of the people want them as park/turn signals we never made a new bracket to use them as a driving light. We remove the driving light bulb and replace it with a clear (amber when lit) bulb for park/turn signals. This bulb is much smaller which is why the current bracket doesn't clear the unaltered driving light.
Old 09-08-2005, 09:43 AM
If they were set up for adjustment, will the outer surround still fit the gravel pan apperture ok ie does the surround stay still & the housing move (I hope that makes sense)
what would the cost be for a pair of front lights & for a pair of RS style rears.I'm in no rush for them so if it takes Pasquel a while to make the proper bracketry to take the brighter bulbs, then no problem. Carriage would have to be to Great Britain. Probably about the same as to Jannes in Sweden
Old 09-08-2005, 06:14 PM
The billet piece doesn't move; the bracket pivots aiming the driving light itself. I'd have to check on the freight, would need a complete address. You can pm or e-mail if you like.
The front lights are $199 shipped, but not to the UK! We will be offering a discount on them very shortly to $179.95 shipped, but we'll have to get you your freight. By the RS style rears, do you mean the taillights? They are normally $253.95 shipped for the set, but will be $230 shipped. If you bought the side markers at the same time there is a 15% discount on all pieces instead of 10% discount quoted above.
