Old 11-30-2008, 09:55 AM
thedugan's Avatar
thedugan thedugan is offline
Distributor is marked and pulled
Collar is not right so I have to adjusted it
Re-priming the motor and the gauge works so its the collar.
Lets up hope I can line up the distributor and just drop it back in.
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
Old 11-30-2008, 10:26 AM
thedugan's Avatar
So far its not lining up with my mark. Gotta keep messing with the oil pump shaft
oh what fun. Its off by an 1/8inch.
Doug L.
Old 11-30-2008, 10:28 AM
awr68's Avatar
awr68 awr68 is offline
Great thread guys! Lots of good info! Thanks for leaving it here and not going to email with this!
Good luck with the restart today!!
Tony
'68 Camaro
Old 11-30-2008, 12:36 PM
thedugan's Avatar
Well it doesn't like the mark I made so
back to pulling the plugs, pulling the wires, hanking the dist, unhooking the hidden crank trigger wire, and bringing it to TDC
the good news is I dont need to read the instructions from Accel on how to phase the dist and rotor. can do it in my sleep now
Doug L.
Old 11-30-2008, 02:43 PM
thedugan's Avatar
we have ignition and oil pressure.
Runs a bit rough but gotta dial in the timing.
gotta get a helper over here Tue night for breakin.
Doug L.
Old 11-30-2008, 03:58 PM
camcojb camcojb is online now
Old 12-05-2008, 02:57 PM
thedugan's Avatar
Well I am so happy. Started it up today and let it run for awhile and it runs great. Synced up the timing fixed some small problems but so far so good.
next todo is my Electric Fans need to be setup to kickon and my tach is not working. Also need to look into a better upper radiator hose setup, what I have now is temporary to get it running. Looking todo something in steal that I can then have powdercoated black. Also need to get the tubing for the supercharger
I shot a short (real short) video of it running.
https://www.youtube.com/watch?v=rxyo3v44w2s
Doug L.
Old 12-05-2008, 03:42 PM
very good, congrats.
