Old 12-04-2008, 02:09 PM
HaulinAsp's Avatar
HaulinAsp HaulinAsp is offline
Originally Posted by 57hemicuda View Post
Love those old Mopar cross rams,you had to watch those most were designed for the Max Wedge heads and had a much taller port opening.they would bolt on,but the ports didn't match.Love the use of old retro parts,really cool.Ron
Wrong. The Long Ram will bolt up to their respective cylinder heads. This manifold design was available on the B engine- 361 and the RB engine being the 413. Both versions would bolt up to your standard 361/383/400 B engines and the 413/426Wedge/440 RB engines.
Now the true MAX WEDGE engines had the heads with the larger port openings, among other differences ( 4 bolt Valve Covers ) ect....
2004 Ram SRT-10/Cummins Conversion- Project RattleSnake
1966 Dodge Charger- Viper Powered Project
Old 12-04-2008, 02:17 PM
joe440's Avatar
joe440 joe440 is offline
thanks for that info, was getting curious about that.
Old 12-04-2008, 02:20 PM
57hemicuda's Avatar
57hemicuda 57hemicuda is offline
Originally Posted by HaulinAsp View Post
Wrong. The Long Ram will bolt up to their respective cylinder heads. This manifold design was available on the B engine- 361 and the RB engine being the 413. Bolt versions would bolt up to your standard 361/383/400 B engines and the 413/426Wedge/440 RB engines.
If I'm wrong I stand corrected,Was it the standard cross ram,that had the tall ports for the Max Wedge heads.It was years ago {like twenty}that I had the mis fit issue on those parts.Just trying to give a freindly warning.Ron
Old 12-04-2008, 09:32 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
very nice can't wait to see the the intakes polished
Old 12-05-2008, 06:42 AM
HaulinAsp's Avatar
The Max Wedge engines (1962,63,and 64) Stages 1, Stage 2 and Stage 3 versions had the taller port openings than the standard wedge ports. Along with the taller ports they included a slightly larger valve dia. to take full advantage of the Cross Rams effective upper RPM band. The manifolds shown above are called Long Rams- not Cross Rams. You could use the Long Ram style on your standard Wedge Engine cylinder head- example- #-906 heads, 452 heads, even the Edelbrock Aluminum Wedge cylinder heads,ect.
The Long Ram engine package was more of a low rpm version, or for better description- street version.
I too have a set of these Long Rams and have toyed with making a simillar style set up to utilize 2 turbos and injection.
I hope this clears things up.
Old 12-05-2008, 02:58 PM
57hemicuda's Avatar
Your right,it was this cross ram i was thinking of.Ron
Old 12-05-2008, 04:28 PM
joe440's Avatar
did some more work on the console last night, its coming out good. And after 2 years of primor finally started painting, did all the jams and engine bay, the rest is getting painted tomorrow. Im very happy with how its coming out.
joe440's Avatar
Old 12-06-2008, 03:05 PM
joe440's Avatar
car came out great
joe440's Avatar
