Old 12-23-2008, 08:13 AM
wiedemab's Avatar
wiedemab wiedemab is offline
Originally Posted by Autokraft View Post
The shock crossmember is mig welded, everything else is tig welded with sil bronze
Just a question about the silicon bronze. I've seen this used before and have done a little research. Are you just using this on the parts that you don't deem structural? It sure makes pretty looking welds. I thought I had read somewhere that it makes a weaker weld and shouldn't be used on structural joints.
I'm just curious - trying to learn.
I like the clearance modifications for the exhaust. You can tell that you've been down that road before with a Camaro. It's always nice to have those previous experiences to draw on.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 12-23-2008, 09:12 AM
Kendall Burleson Kendall Burleson is offline
Killer car nice
Old 01-07-2009, 08:48 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Color is going on...
My LS7 69 Camaro
Old 01-07-2009, 08:58 PM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
Correct. Non structural- sheetmetal. Like you would not want to use it for welding the subframe to the subframe conectors or welding together a roll cage
Autokraft
Old 01-07-2009, 10:22 PM
awr68's Avatar
awr68 awr68 is offline
Progress! Looks great Kurt!!
Tony
'68 Camaro
Old 01-08-2009, 06:44 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Originally Posted by XcYZ View Post
Kurt cut in the Stielow inspired trunk floor recesses and the bottom of the car gets media blasted on Monday, then it's full speed ahead with paint!
The Lemons headers fit great - even with the 2" primaries.
I've heard a lot of good things about those Lemon's Headers.
What are your opinions? They look like they fit awesome.
THANKS!!
Old 01-08-2009, 08:26 AM
THANKS!!
They do look having a great fit!! Why they dont make those in stainless? I would take a set asap
63 Z06
Old 01-08-2009, 09:24 AM
Autokraft's Avatar
Supporting Vendor
Autokraft.org
Well I will say this, they fit awesome, look awesome, quality is awesome, they tuck up nice and dont hardly hang down below the frame, easy access to the plugs, nice beefy flanges.... plus Dan is great to work with
Autokraft
Old 01-08-2009, 01:18 PM
61Bubbletop's Avatar
61Bubbletop 61Bubbletop is offline
Lateral-g Moderator
Nice work Kurt...Car look fantastic!
Old 01-08-2009, 05:29 PM
XcYZ's Avatar
Closer...
My LS7 69 Camaro
