Old 12-27-2008, 03:31 PM
ttchevelle's Avatar
ttchevelle ttchevelle is offline
Default flywheel question
I have a ls1 with and eagle crank,hughes hp4004 flexplate and the converter hub spacer also from hughes. I bought arp flywheel bolts but they seem to be too long. Do I have to run the crank spacer with this flywheel for a th400 converter and this set up? If so anyone have the part number? Thanks!
1965 chevelle ls1 twin turbo/th400/currie 9 inch
