Old 01-07-2009, 07:10 PM
skatinjay27's Avatar
Originally Posted by awr68 View Post
Stock width rear end or narrowed? If you haven't done the rear end yet just order the b.s. you want and then mock them up and measure for the rear end width...it's truely the best way to do it!
For the front we need to know what aftermarket subrame....it does make a differance....
2nd this! its the best way cause you get the exact size lip you want. and yes the front subframe matters they are different track widths.
also another factor to remember what brakes you plan to use and if they chance the track width, how much/thick are the calipers..so the wheel pads are built thick enough to clear the face of your calipers.
AJ
