Old 09-19-2005, 05:48 PM
XcYZ's Avatar
XcYZ XcYZ is offline
I had no idea it was a tri-coat. lol It sure didn't look like it. Oh well.
My LS7 69 Camaro
Old 09-19-2005, 06:16 PM
awr68's Avatar
awr68 awr68 is offline
Just followed a '05 GTO on the way home tonight, that red sure looked good!
Tony
'68 Camaro
Old 09-19-2005, 06:43 PM
67Sally's Avatar
67Sally 67Sally is offline
My Mustang is "Malino Red". It is a Honda/Acura color. I know that the newer versions of it are tri-coat but if you go back a few more years it is not. I don't know paints but that is what I was told when I had a new hood painted. I will dig up my paperwork and provide the details.
W.
Here is a picture of my car before its current tear down. (Thanks for the instructions Bill)
William Rouleau
Project PonySnake
Old 09-19-2005, 08:49 PM
Musclerodz's Avatar
It can be used as a bc/cc or tri-coat. The formula for the base is the same for either. The mid coat has just enough magenta in it a color the binder. I for one would just leave the mid-coat out. I will be having a 1/2 pint mixed up to shoot. The nice thing about Milano is it has ALOT of pigment.
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 09-19-2005, 10:27 PM
907rs's Avatar
907rs 907rs is offline
W.
(Scott how do I attach a picture?)
William, try this:
To attach a file to a new post, simply click the [Browse] button at the bottom of the post composition page, and locate the file that you want to attach from your local hard drive.
Only certain types of files may be attached: these are the valid file extensions for files to be attached to this forum: bmp doc gif jpe jpeg jpg pdf png psd txt zip.
After posting, the attachment will show up in the body of your message. To view the contents of the attachment (if it is not already displayed) simply click the filename link that appears next to the attachment icon .
Or send it to me- [email protected]
Bill
Old 09-20-2005, 05:45 AM
XcYZ's Avatar
Mike
Thanks Mike, I didn't realize that. Obviously I'm out to lunch on the technical side of paint.
My LS7 69 Camaro
Old 09-20-2005, 04:29 PM
68protouring454's Avatar
Default muscle
that makes no sense.
most normal 3 stage paints, have a ground coat, which usually is alot light and full of pearl/metallic. then the mid coat is a darker shade of main color (lets say red) and very translucent (does not cover well) and it takes 3-5 coats to darken the ground coat or till you reach the color you want or are trying to match, dodge did a bunch of 3 stage colors on there cars etc in the early 2000's, a real **** up, heres some i just did last week, and there is no way you could get same color from ground coat with no mid, or by mixing same color in 2 stage, no way.
this is a pic of the 3 stage i just did i repair to, on a 2001 dodge mini van, color is inferno red.
first pic is mid coat(2nd coat) 2nd pic is color of mid coat, 3rd pic is ground coat can,4th pic is ground coat, which is first coat
see how in mid coat pic, it is very translucent on top where you can see right thru it then on bottom it is dark as there is more down there, then over on ground coat you can see how much pearl/metallic is it, thats the whole deal to 3 stage is you can spray the mid coat till you get desired darkness or effect if doing an overall, and it will look entirely different if you put one coat of mid coat or 4 coats of mid coat.
Old 09-22-2005, 05:27 PM
awr68's Avatar
Just got word from Stielow (threw a friend) that the Red Witch is a '94 Mopar color in Sikkens.
Tony
'68 Camaro
Old 09-22-2005, 06:39 PM
race-rodz race-rodz is offline
late 90's ford color i beleive called rio red... its a solid non-metalic red that used a "base" red, and a transparent red mid coat, although there is an alternate formula that is standard BC/CC.... that matches better than the tri-coat formula.
there are a lot of options on the "right" red in ones eyes.... my personal flavor is viper red...i like the orange tint.
Old 09-22-2005, 08:24 PM
awr68's Avatar
I saw a '06 Jetta in Salsa Red the other night that looked nice, it's a deep, but still true red...that's what I'm looking for!!
Tony
'68 Camaro
