Old 02-02-2009, 07:39 PM
camaro2nv's Avatar
camaro2nv camaro2nv is offline
Default 1st gen rearend and suspension
Ok so Im looking for a rear axle complete along with a suspension that will allow shockwaves. Car is tubbed and the wheels are 20x12 with a 5.5 backspace. What do you suggest?
Old 02-02-2009, 07:43 PM
ironworks's Avatar
We can build whatever you need. Call me at the shop
Rodger
Old 02-03-2009, 10:10 AM
Silver69Camaro Silver69Camaro is offline
We've had great success with our direct-fit rear clip:
Available in triangulated 4-bar and 3-link. The tri 4-bar clip requires no floor cutting whatsoever, and the three-link allows you to still retain the rear seat. Imagine being able to replace your .045" thick 2x3 frame rails with a mandrel-bend 2x4x0.120 welded assembly. Talk about a stiffness improvement! You can keep your stock fuel tank too with minitubs.
Same suspension used in our 3G Vette that turned over 1.05G on undersized tires. It works!
Matt Jones
Mechanical Engineer
Art Morrison Enterprises
Old 02-03-2009, 02:23 PM
Mrfixit Mrfixit is offline
Thumbs up
Sweet!
Old 02-04-2009, 10:01 PM
crazycarl's Avatar
crazycarl crazycarl is offline
If you're in Roseville CA, Chassisworks is right around the corner. They have a couple different options that would work for you.
I'm probably just screwing with you, so please don't take it personal.
Old 02-04-2009, 10:05 PM
camaro2nv's Avatar
REALLY? I was really set on the AM 4 link but it would be nice to see the CW in person.
Old 02-04-2009, 10:25 PM
fxstdale fxstdale is offline
ame 4 link is the way to go
Old 02-13-2009, 01:38 PM
ViperBlue68's Avatar
ViperBlue68 ViperBlue68 is offline
Location: Yuba City, CA (about 1/2 hour North of Sacramento)
That looks great! VERY interested in getting this how bad is shipping to 95991? also what width is the 9" housing? I want to run 20x12s in the rear
J.T.
Old 02-16-2009, 06:08 AM
You can get pretty much any width axle housing you want. Normally for a 12" rim we recommend a 47.25" housing (housing width, not axle mount surface width) and 4.5" B.S.
Shipping is somewhere around $500 fully loaded, but don't quote me on that!
Matt Jones
Mechanical Engineer
Old 02-16-2009, 03:20 PM
where are the mounting points on this setup?
J.T.
