Old 02-10-2009, 06:23 PM
bowtie_nut's Avatar
bowtie_nut bowtie_nut is offline
Default 6.0L LQ4 Fuel injection
Okay fuel injection guys I have a question. I have a 99 silverado with a 6.0L factory engine. It has problems starting. The engine sounds like it is starting so I let off the ignition and it dies. Some times it will start and run fine, then I shut it off and try it again and it won't start. The check engine light never comes on at any time. I have checked the fuel regulator on the fuel rail and cleaned around the throttle body with carb cleaner. Does anyone have any ideas?
Old 02-10-2009, 06:36 PM
youthpastor's Avatar
fuel pressure test? spray some carb cleaner in t-body to see if it starts- if i had to guess- fuel pump- pressure drop will cause hard - no start especially cold- if it is put an A/C Delco pump in it- not aftermarket- my 2 cents- Chris
Old 02-10-2009, 06:39 PM
bowtie_nut's Avatar
when I take the intake ductwork off of the throttle body the engine dies, is this normal?
Old 02-10-2009, 06:43 PM
cant do that- has to run through maf sensor to stay running- i thought it wouldnt start??
Old 02-10-2009, 06:45 PM
bowtie_nut's Avatar
it will start every once and a while. Once it is running it runs fine. It is just a matter of getting it to start
Old 02-10-2009, 06:50 PM
how old is the fuel filter?? sounds like the pump is weak- hard to start cold??
Old 02-10-2009, 06:54 PM
bowtie_nut's Avatar
filter has around 5 years on it and the pump was replaced last summer.
Old 02-10-2009, 06:58 PM
yep start with the filter (plugged) - it should be replaced more often- check the fuel pressure- there should be a shrader valve on the fuel lines- i can look tomorrow for specs at work or google it - maybe someone can chime in here- but i think it should be all of 50psi- good luck- Chris
Old 02-10-2009, 07:00 PM
bowtie_nut's Avatar
thanks for the help
Old 02-11-2009, 06:56 AM
fuel pressure on any LSx engine which includes the iron truck engines should be 58psi at all times. The engine should crank and run with 50 psi but there's a problem if you've only got 50 psi
