Closed Thread
Old 03-20-2009, 01:27 AM
Lucky you were only doing 50 in that 35.....
  #502
Old 03-20-2009, 01:31 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
That looks like about $150.00....that sucks.
If you get one from LVMPD let me know right away so I can try and work some magic for you. Sorry but Henderson is beyond the range of my voodoo.
Curtis
  #503
Old 03-20-2009, 09:27 AM
I got one of those in December too. The radar detector may have to come to fruition.
  #504
Old 03-20-2009, 01:31 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Exclamation
That sucks.
I bet it's tough to keep off it in that mean, black machine!!!
  #505
Old 03-20-2009, 07:27 PM
awr68's Avatar
awr68 awr68 is offline
Originally Posted by 98ssnova View Post
Leave me alone Curtis, Anthony said to be nice so I am jerk.
Sorry, that was not directed to you, 68 blackbeauty was really pushing it and I guess I should have been more specific. Again sorry, you are an asset to this site and I agree with what you had to say to him!
Tony
'68 Camaro
  #506
Old 03-23-2009, 08:53 PM
Lenie's Avatar
Lenie Lenie is offline
For you guys running the DSE sub. Do yourself a favor and have them weld on the Z bar bracket. The inner fender makes this a real pain in the you know what. It's tapped and done right but......it was a last minute change. The clutch rod etc. is on the top of the list. She is a dirty pig right now and needs some touch up. Somehow the inner fender got all scratched to **** on the way here. Of course no steering was probably the cause.
The boys over at ATS have been treating me right. Here is the solution to my crossmember issues. They modified it with one of their T56 crossmember ends and moved the center bracket slightly. Of course it still needs painted. ATS is top notch. Highly recommend them.
I added fuel tonight to prime the fuel system and check for leaks. I had 4 leaks. Two at the carb bowls and the fitting on both sides of the pump. I used a pipe dope and the fuel ate right through it. Lucky me!! I had to disasemble all the fittings with the dope and replace it with tape. It's all fixed now but what a mother ######. The carb leaks were caused by a frankly crappy design. They used two gaskets with my high dollar fuel rail. I used the gaskets and tape and it's not leaking anytime soon.
Got a question for you, pm sent.
Lenie
  #507
Old 03-24-2009, 12:10 AM
monza's Avatar
monza monza is offline
Get the V1 it is truly amazing! Then... a laser jammer.
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
62 Corvair Greenbrier
http://www.sourceboards.com/
  #508
Old 03-24-2009, 12:43 AM
Agreed. Love my V1. Have it hardwired. Gotta get that as a minimum. Laser jammer is nice, however illegal in Calif.
  #509
Old 03-24-2009, 10:21 PM
Ya....I think you guys are right. That or I need some quiet mufflers. Here is my chassis dyno numbers for the thread.
  #510
Old 03-25-2009, 12:42 AM
Spiffav8's Avatar
Lateral-g Moderator
The car sounds perfect!
Curtis
Closed Thread
