Old 04-20-2009, 06:17 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Default Added Auto Meter DPSS shift light
I finally got my Auto Meter DPSS shift light installed. I mounted it directly above the column and moved the Wideband O2 gauge down next to the wiper switch. I wasn't excited about cutting a 2" hole for the wideband, but it went without issue.
While I had the dash out, I made a harness that hooks up to the wideband O2 output and hooked it up to my EFI Live and can datalog the AFR. Pretty slick.
The DPSS is programmable (RPM, launch help, and color) and hooks up to the tach for 90 seconds of playback. Here's what it looks like when the shift light comes on (you can set the intensity for day and night)
My LS7 69 Camaro
Old 04-20-2009, 07:11 AM
camcojb camcojb is online now
that would definitely catch your eye, looks good. Having fun with the EFI Live?
Old 04-20-2009, 07:37 AM
XcYZ's Avatar
EFI Live is amazing software and I'm having a lot of fun with it. I got the calc_pid.txt setup for the conversion of the 0-4v output of the Auto Meter wideband to show as AFR, but it took a bit of looking before I realized I had to use the EXT.AD1 PID for it to update/display on the dashboard and data tabs.
My LS7 69 Camaro
Old 04-20-2009, 07:39 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Nice setup! Looks like you have a good clear view of the gauges and the shift light is sick!
Curtis
Old 04-20-2009, 07:41 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
I agree!!
Old 04-20-2009, 02:54 PM
MattG's Avatar
MattG MattG is offline
Very cool...the last thing you want is a big ugly light stuck on top of the dash.
I like your DSE panel setup the best!
Matt
'69 Camaro Coupe, Full Ridetech stage 3 suspension, moser wavetrac 12bolt, Forgelines, Ls3 Heads/Cam,T56 Magnum. Built by me and tuned by Ed!
'69 'Vert Camaro: DSE Sub-Frame, DSE Mini-Tub, DSE Four-Link w/9inch. LME LS7 427, T56. Tuned by Ed Hutchings, :SOLD!
Old 04-20-2009, 03:15 PM
7TSS's Avatar
7TSS 7TSS is offline
Agreed that it looks a lot cleaner mounted in the dash instead of sticking out attached to something. I really like the way it lights up at night.
Goodwin
Old 04-20-2009, 03:30 PM
chicane's Avatar
chicane chicane is offline
Schweeeeeet...
Old 04-20-2009, 04:42 PM
That looks super hi tech!
Old 04-20-2009, 04:57 PM
awr68's Avatar
awr68 awr68 is offline
Love the way it all turned out Scott!!
This might sound weird...but does it come with a cover like the standard shift lights...for street driving?
Tony
'68 Camaro
