Old 04-16-2009, 04:03 PM
rallye455 rallye455 is offline
Default ? About Fuel Injector Sizing
Can you get away with runing a larger fuel injector on an engine with an aftermarket computer such as the Accel Gen 7? I dont want to have to buy another set of injectors later as the motor gets upgraded.
Old 04-17-2009, 06:47 AM
camcojb camcojb is online now
yes, but how big are you planning on running?
Old 04-17-2009, 09:21 AM
I need 36lb now but have access to a set of 65lb
Old 04-17-2009, 05:18 PM
I've run that size and quite a bit larger without issue with FAST and BS3. Actually, we ran 75's with the Gen VII setup on a procharged small block and it was fine.
You can run into resolution issues where idle can get funky as an injector gets sporadic when you try to get the pulse width too small, but I've never had that issue. All of mine, even with 95's have idled just fine.
Old 04-17-2009, 07:13 PM
thanks alot...saves me from wasting anymore money....
Old 04-21-2009, 10:29 AM
Pantera EFI Pantera EFI is offline
Default Injector Sizing : Batch vs Sequential
For the correct answer, FIRST ask "How many times will I fire the injector per cycle" ?
The low grade system will fire the injector each crankshaft revolution, BAD for 75's.
A better grade EMS ('882, BS-3, etc.) can fire the injector ONCE per cycle (two crank revolutions) GREAT for 75's.
Lance
