Old 04-21-2009, 04:44 PM
DHARROD's Avatar
DHARROD DHARROD is offline
Default Black Diamond - Finished
I forgot to update everyone with the finished product last summer.
Here are some of the specs. I had planned to finish of the transmission/rear end but kept it stock due to the economy and job outlook. Things keep going the way they are I'll have to sell it to pay the morgage.
Engine / Drivetrain
Original 396 block and steel crank
Dart Pro 1 Heads
Aluminum Roller Rocker Arms
PBM Eliminator Hydraulic Cam
Edelbrock Air-gap Intake
Mallory Ignition Box
MSD Pro-Billet Distributor/Coil
PowerMaster Starter
750 Barry Grant Mighty Demon
Holley Peformance Fuel Pump
Aeromotive regulator
Stainless Steel Gas Tank direct from Rick’s Hotrod Shop TX
Stainless steel gas lines by Right Stuff Detailing
Aluminum radiator by Alumitech Reproductions
Fex-a-lite dual 27” electric fan
Munci 4-Speed (M-21)
Hayes Performance Clutch
Stainless Steel Hooker Super Comp Headers
Magna Flow 2-1/2” Stainless steel exhaust
Stainless Steel exhaust tips by Pypes Performance
Fan-shroud by Undercover Solutions
Suspension
Silver powder coated frame by Top Coat Inc. Raleigh NC
Original 12 Bolt (3.31 gears) with Eaton Posi
KMA 1-1/8” Front sway bar
KMA Rear sway bar
Upper/Lower Rear Tubular Control Arms by UMI Performance
Tubular Upper/Lower A-arms by BMR Fabrication Inc
Moog Steering Components with Solid Aluminum couplers
Hotchkis F/R springs 1” lower
Edelbrock Performer IAS Shock Rear
QA-1 Font Coil Overs
Energy suspension bushings/body mounts
Front Wilwood 13" 6 piston Superlite Drilled and slotted
Rear Wildwood Brakes - 12.2" 4 piston Dynalite Drilled and slotted
Wilwood Master Cylinder with Hydratech Braking System
Stainless steel break lines – Right Suff Detailing
Energy Suspension bushings and body mount
Stainless Steel body mounts & bolt kits
17” Budnik Rims
Nitto 255/50 front 275/50 rear
Body/Interior
Original Sheet metal
DuPont paint system: Primer, Sealer, Jet Black Base, Clear
Black Interior; bucket seats 4-Speed
Tilt Wheel
Gauges by Autometer
Original AM/FM Radio – modern internals/IPD ready
Digitails LED – tail lights/front blinkers
Modern dual beam head-lights
Old 04-21-2009, 04:45 PM
hifi875's Avatar
hifi875 hifi875 is offline
Default black diamond
sweeeet!!!!
Old 04-21-2009, 04:54 PM
DOOM's Avatar
DOOM DOOM is offline
Thats beautiful man!!! NOTHING LIKE BLACK
Mario
USCOLLISION
Old 04-21-2009, 05:28 PM
almcbri's Avatar
almcbri almcbri is offline
that car is killer! nice work
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 04-21-2009, 05:31 PM
Ketzer's Avatar
Ketzer Ketzer is offline
Wow! Beautiful 69!
Old 04-21-2009, 05:56 PM
WILWAXU WILWAXU is offline
Nice looking car!
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 04-21-2009, 07:49 PM
7TSS's Avatar
7TSS 7TSS is offline
Your car came out sweet!!!!
Goodwin
Old 04-21-2009, 09:02 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Wow, that looks awesome!
My LS7 69 Camaro
Old 04-21-2009, 09:15 PM
dodge dodge is offline
Niceeee
Old 04-21-2009, 09:57 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
70 Chevelles used to be my favorite year but that is one sweet 69. Beautiful car. I have a 69 SS El Camino I need to get busy on building.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
