Old 05-07-2009, 10:32 PM
ohcbird's Avatar
ohcbird ohcbird is offline
Default Procharged 434 BBC, 586 rwhp
SOLD SOLD SOLD
434 longblock originally built by Golen's Engine Service in NH, purpose built for the D1SC Procharger setup. Proven 585 rwhp in my 68 Camaro as seen below (behind a TKO). Idles nice with a slight blower whine, has torque all day and then some. Has about 4400 miles on it, with a few passes at the track. I'm a military officer with 21 years in, so hopefully, you'll know that I'm not here to seel crap or rip anybody off. I'm doing a full Jakes chassis with an L92 swap...so she needs a new home.
I also have the DFI setup and a set of Edelbrock heads for this engine if you're game...I've seen similar combos make 700+rwhp on pump gas.
Longblock Specs: GM steel crank, GM forged rods with ARP bolts, 8.5:1 JE blower pistons/rings, Comp cams hydraulic 233/237 /114 blower cam, ported factory closed chamber oval port heads with Manley 2.19/1.88 valves. Comp magnum rockers, cloyes timing chain, melling high volume pump, BHJ balancer.
Intake- Edelbrock RPM-O, with a BG 800 Demon, Aeromotive fuel regulator. Extreme Velocity carb hat (I have a shorter one if you need it).
Exhaust- coated Hooker Super comp headers. Obviously, they are only designed to fit 67-69 BBC F-bodies.
Ignition- All MSD: distributor, 6A box, coil, etc.
Supercharger- recently overhauled (by ATI) D1SC, with an SDCE bracket & tensioner kit (these are NOT cheap). Currently setup to make 10psi, with a street bypass valve, but I have a Procharger adjustable 'race' valve that will allow you to go higher if needed. Extra SC fluid also included. Extra pulley also included.
More details if you need them- pic & video below. $6000 OBO with complete front accessories & blower setup. Drop it in & go! The SDCE blower setup will run you just south of that. Currently located at Jake's Rod Shop in Maine; we can work something out for delivery in the NE if needed. Contact me at [email protected] finders fee if you help me sell it!!
JEFF
Old 05-07-2009, 11:27 PM
sweet setup!
Old 05-07-2009, 11:51 PM
*rayman*'s Avatar
*rayman* *rayman* is offline
will you consider selling the procharger setup by itself? PM me, i'm very interested.
68 BB SS Camaro - building it in Australia, where everything costs twice as much as it costs in the U.S.
Fuel prices suck!
Old 05-08-2009, 03:57 AM
ohcbird's Avatar
Default SC setup
At this point, I'd like to keep things together. If someone doesn't want the Procharger, we can try to work something out.
Old 05-08-2009, 09:16 PM
fillpot fillpot is offline
PM sent.THANKS!
Old 05-08-2009, 09:30 PM
ohcbird's Avatar
Default engine PMS
All PMs and emails replied to...thanks for your interest.
Jeff
Old 05-11-2009, 06:21 AM
wookham's Avatar
wookham wookham is offline
no call yet??
Old 05-11-2009, 07:28 AM
ohcbird's Avatar
Default engine
Sorry Jeff; I did get your email...standby for a call today.
fillpot- PM replied to
(the other) Jeff
Old 05-13-2009, 02:15 PM
CE69 CE69 is offline
PM sent. Thanks Chad
Old 05-22-2009, 08:05 PM
ohcbird's Avatar
Default Sold
Engine has been sold...Thanks Chad.
