Old 07-04-2009, 07:03 PM
scottybuck 11 scottybuck 11 is offline
Default Gas Guage Wont Read.
put my narrowed tank in from dseand it only reads a quarter of a tank.whats my problem fellows?
Old 07-04-2009, 07:41 PM
JamesJ JamesJ is offline
You most likely need to give a bit more info, factory gauge? all you did was switch the tank? nothing else changed?
James J.
Old 07-04-2009, 07:47 PM
i have autometer guages.it was working fine.i minitubbed the car so i had to put in the narrowed tank and a dse sending unit.now my guage reads 1/4 of a tank when its full.
Old 07-04-2009, 08:03 PM
dhutton dhutton is offline
The new sender has to be the same resistance as the old one to read correctly. Sounds like it is not.
Old 07-04-2009, 09:05 PM
1984 camaro's Avatar
1984 camaro 1984 camaro is offline
Float could be hitting the tank. You said it worked before and you narrowed the fuel tank ? and it does not work now. thats what you should check
Old 07-04-2009, 09:35 PM
jpdeuce's Avatar
jpdeuce jpdeuce is offline
I bet the float is sticking or hitting something making unable to get full travel. I have had this happen before with both DSE and stock tanks.
Old 07-05-2009, 02:36 PM
WicKeD_SS's Avatar
WicKeD_SS WicKeD_SS is offline
lol I have the same problem, just havent had time to drop the tank and see whats going on. If i get to it soon ill let you know what I found out.
WicKeD
Old 07-05-2009, 06:48 PM
Van B's Avatar
Van B Van B is offline
I have same problem since I put in my Rick's tank. Ordered a VDO sender 0-90 ohm. Wonder if I got the wrong part by mistake.
Jeff
99 Miata LS6
67 Camaro Street Fighter 599 HP L92-SOLD
Old 07-05-2009, 10:37 PM
BritishGreen68 BritishGreen68 is offline
ya the float in the tank probably wont go all the way up for whatever reason.. happens pretty often, usually you buy a car and find that out later though lol..
Chris
Under construction-British Green 68 Camaro-
