Old 06-18-2009, 02:46 PM
ironworks's Avatar
Originally Posted by skatinjay27 View Post
didnt you know that if you paint a car orange and have a custom front splitter then it looks like velocity...
just like if you paint a car or TRUCK flat green its a bite off of the f-bomb!
digging the rendering alot!
Are you not aware that F-bomb Copied the ARMY.
Old 06-18-2009, 03:14 PM
James OLC's Avatar
You should see what happens if you paint your first gen ... never mind...
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 06-18-2009, 03:15 PM
skatinjay27's Avatar
LOL that funny, i was actually gonna use that as an example also!!!
some people...
AJ
Old 06-18-2009, 06:14 PM
nvr2fst nvr2fst is offline
Rodger, Lookin good great body lines on both models LOL.
Hats off to Carter.
Old 06-18-2009, 11:01 PM
It looks exactly like Velocity except for the wheels, carbon fiber, windows, graphics, etc.. I really didn't feel that way but it's clear it's way different. I really can't fault him for saying it since it's his opinion, however.
Old 06-19-2009, 01:29 AM
blowngasr blowngasr is offline
yeah,roger i like the color to,that looks like southern california tan. not sure of the paint code....could be 38...or 24...maybe 36...jim
If you look close you will see an orange AUDI buried in the back ground of this picture. Look close it can be hard to find. I like this shade of orange alot. The girl is not to bad either.
Tyler From Anvil Auto thinks it looks like this monster.
[/QUOTE]
Old 06-19-2009, 04:39 PM
paulk68 paulk68 is offline
did you say you heard a rumor for carbon fiber doors???? if so
Old 07-21-2009, 10:47 AM
David Pozzi's Avatar
check on the legality of those tires for Optima Challenge. I think they require a treadwear of 100??? Might be different this year though.
I think drums will be lighter than discs in this case. We replaced 2nd gen discs with Baer 13" Track kit and saved 2 lbs.
The bar weight can be estimated from a steel chart having diameter and length.
Stock bar weighs 5 lbs.
http://www.PozziRacing.com
Old 07-21-2009, 12:18 PM
ironworks's Avatar
I have another set of KDW2's that came but I have lagged on trying to get all the updates togther.
The weigh differences will be all over the board on different things. We wound up running some 14" Wilwood brakes front and rear. A big brake modded subframe ends up in the same zone with tubular a arms and ATS spindles. But you have to lower the suspension pretty low to give it the look. The aftermarket subframes give you a lower ride height and a clean slate design which end up give you some benfits a stock sub could never due or was intended to do. Wider tires, stronger front clip design, new unbent used parts.
I should have an update very soon, We are working on the trunk floor and quarters and building our mini tubs currently.
Old 07-21-2009, 12:36 PM
Jr's Avatar
Jr Jr is offline
Rodger,
What new with this car?
