Old 08-01-2009, 04:07 PM
Default another good reason to use DEI hose covering
with the twin turbo heat management and protection is crucial. I use the DEI hose covering for many of my hoses and electrical lines for the heat protection, and because it comes in black which looks good.
Today went for a short spin, getting ready for Hot August Nights in Reno. When I came back I could smell gas, and saw gasoline pouring out under the car. My main #8 feed line to the fuel rails had split and was leaking gas badly , due to 45 psi used in efi. Because I had that line covered in DEI heat barrier wrap it made the gas follow the covering down under the car and exit at the frame where the covering stopped. If I would not have wrapped that line it would have been spraying on the turbo downpipe, and I cannot imagine anything less than a major fire resulting.
I got lucky, but figured I would at least share a side benefit to an aftermarket item that I had not considered.
Old 08-01-2009, 04:28 PM
Wow ! Go buy a power ball ticket!... Glad to hear it ended well.
You plan on replacing the fule soked DEI?
Old 08-01-2009, 05:14 PM
awr68's Avatar
awr68 awr68 is offline
That could have been REAL bad!
Tony
'68 Camaro
Old 08-01-2009, 05:37 PM
Jody -- Glad you survived that nasty little surprise!!
Let's not have any HOT August nights tales like that....
Old 08-01-2009, 05:41 PM
70rs's Avatar
70rs 70rs is offline
WOW!! Glad everything turned out ok. I'll keep that in mind when I get to plumbing mine.
And buy a fire extinguisher today. Unless you would rather have the insurance money.
Old 08-01-2009, 06:39 PM
jmac jmac is offline
aw man that is awful!
What brand line were you using? I remember a thread either here or on PT.com about the braided lines being garbage and that the swell and get soft over time and eventually split. You might have brought this subject back to life.
Glad you're ok and the car also!
My 1967 Camaro
Old 08-01-2009, 06:40 PM
have one..................
Old 08-01-2009, 07:04 PM
bentfab's Avatar
bentfab bentfab is offline
When in doubt hard line it !! Glad everthing is safe and sound. By the way that fire extinguisher and mount is sick.
Follow us on Instagram = @bentcustom
www.bentcustomandperformance.com
Old 08-01-2009, 08:28 PM
Dayton's Avatar
Dayton Dayton is offline
I want that mounting hardware. Telll me where.
