Old 08-19-2009, 12:51 PM
Naaaah....540 and solid roller. El Natural way.
Old 08-19-2009, 01:08 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
VERY NICE!!! My man!
Old 08-20-2009, 10:08 AM
gmorris gmorris is offline
If the limitation is only fuel and you have enough pump (and I do) shouldn't one be able to swap injectors and up the max even more? Unless the limit becomes airflow through the throttle body. My 540 dynoed at 750HP and I would love to try this system as it would allow me to keep my port matched intake. My fuel system is already built for EFI with an A1000 and full return system.
Old 08-20-2009, 10:32 AM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Ok, question for you smarter guys. What really makes this better than say Holley ProJection TBI or similar TBI setups? That all this basically is, right, TBI, albeit with what appears to be a much neater, compact install? The ECM/electronics? At 43psi it does seem to run much higher fuel pressure than common TBI systems.
And how might this work on an LS1 with a carb intake? I guess you'd still use the msd ignition unit used for carbed LS motors and follow the directions for CD ignitions. Reading the instructions has raised my interest in this a bit.
Scott from NJ
Old 08-20-2009, 12:33 PM
BBC69Camaro's Avatar
Just get one of the tall deck Dart blocks, and go for a super stroker something over 700cu
Old 08-20-2009, 12:40 PM
ccracin's Avatar
ccracin ccracin is offline
I agree. I would think injectors would do the trick. I don't think airflow would be an issue. I have talked with FAST about this system. You have to disregard some of what is in the instructions. Some of the options they speak of are coming, but not available yet. They said the next 90 days would show more with this system. My eyes are on it. Very interesting.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 08-20-2009, 02:35 PM
EZ EFI is a learning program. Teaches and tunes it self.
Frank Serafine
Old 08-21-2009, 07:35 AM
Steve1968LS2's Avatar
Street Rodder did an install and loved it.. very easy to install.
I will be installing one on a dyno engine for a story and then will be putting it in a certain well known second gen for some "real world" evaluation.
The only downside is that it's only viable up to 600 hp, but it still covers a majority of the people out there.
Will report on how well it goes on in two weeks.
Old 08-21-2009, 07:37 AM
The problem is that there are only four injectors, so it's only possible to support so much horsepower. It's not like you can put 95-lb injectors in there. lol
I forgot what the calculation is for injectors based on HP is.. I need to look that up.
Old 08-21-2009, 07:39 AM
Yea, it's easier... The main difference is that you don't even need to change the intake, so it's closer to being like a carb swap. I don't know whay it wouldn't work with an LS engine.
