Old 08-27-2009, 06:52 AM
I sell and install both. The Quadralink is great, requires a lot more labor, cutting, wleding to install. Also reauires a lot of welding on the rear housing, cutting ends off, rewelding, etc. The G Bar / Prodigy Bar is a great suspension also, rides good, handles well, and is easy to install and requires only minor welding on the rear end housing.
I do believe the 2nd gen Quadralink has a slight performance at the high end of the performance scale in a full on race application. But the Quadra Link will cost a lot more in materials, labor and time.
It is a ways off, but once a G Link is designed for second gens, I suspect any performance gap will be reduced.
Both will ride great and will handle and ride great. Can you do the cutting and welding? Or afford to pay to have it done. Then the choice is simple right now.
Frank Serafine
Old 08-31-2009, 10:56 AM
The T-man The T-man is offline
So you are saying Gbar then...
Old 09-02-2009, 08:35 AM
markss28 markss28 is offline
I have hotchkis springs all the way around on my 73 camaro. I have a 18x10 in back and an 18x8 in front. I have 285/35/18 tire and can go without rubbing a 295/35 tire. This to me looks great and handles very well. The front looks great too and does not rub even when I cut a whole coil off to get it to drop a bit more. I would buy the entire hotchkis stuff. complete bolt on no lie stuff.
Also I think Mari Pozzi runs this in her 2nd gen and she beats everybody.
Never Stay Stock
Old 09-02-2009, 09:23 AM
syborg tt's Avatar
Okay I would love to see pics of your car.
marty-mj
Old 09-03-2009, 08:43 AM
Coming soon to a website near you. Maybe this weekend.
Never Stay Stock
Old 09-03-2009, 09:11 AM
syborg tt's Avatar
send me the pics and I will build you a quick gallery on Garagescene.net
[email protected]
marty-mj
Old 09-04-2009, 10:28 AM
Marcus SC&C's Avatar
Taking things from a technical aspect with no fan coolaid involved, the Quadralink has excellent roll steer characteristics and a slightly more stable (vertically) roll center than the G-Bar. The G Bar is much easier to install, is less expensive, has better anti squat (easier to put power to the ground) and has two optional anti roll bars, including a 3 way adj. frame mounted one. This gives you many more tuning options and allows you to get hardcore wheel rates with more suple spring rates and a better ride. Both use rubber bushings, G Bar uses some poly g. also. The G Bar can be upgraded with SC&C billet double adj. arms with greasable forged Johnny Joints which are offset inboard for even more tire clearance, have better lateral axle location capabilities and save weight. They look cool too. Mark SC&C
