Old 12-17-2009, 11:56 AM
lhkustoms's Avatar
lhkustoms lhkustoms is offline
Originally Posted by GrabberGT View Post
...... Keep me on the short list for a pair.
Will do pm me your contact info
Luke Mau
L & H Kustoms
Old 12-17-2009, 09:51 PM
69sponge's Avatar
69sponge 69sponge is offline
The spindles for my camaro arrived last week, and look great.Ill jump on the install after the holidays and report back then.
Old 01-06-2010, 06:07 PM
lhkustoms's Avatar
L & H Kustoms & Pro Billet Components is proud to announce our new Bumpsteer corrected Pro Billet™ Steering arms for the F and X body cars. These steering arms are machined from ultra strong billet aluminum and have a 304 Stainless steel tapered tie rod insert to prevent fatigue. They have revised geometry to reduce bumpsteer to almost zero. These arms are designed after the "short" f,x body steering arms. They are a great compliment to our Pro Billet™ Tall Spindles or can be used with oem style spindles to cure the massive bumpsteer found in the original steering arms. They come standard black anodized. They Retail for $275 They are in stock ready to ship.
Luke Mau
L & H Kustoms
Old 01-07-2010, 07:40 AM
Luke, can you give me more info on the rear C5 brackets for GM 10 bolts?
Will it work with the C5 parking brake?
Will it bolt right on or will extra spacers be needed or anything else be needed?
Cost?
Basically, I want C5 rear brakes complete with parking brake to compliment my C5/6 front brakes. Will this bracket allow me to do this for my 79TA?
Also, your bump steer arms, are they 1st or 2nd gen applicable?
Old 01-07-2010, 08:55 AM
lhkustoms's Avatar
Cost?
Trey, Our rear brake brackets will work on your 79TA. We offer 2 different rear brackets for the 10/12 bolt. one without provision for the parking brake $125 and one with provisions to run the factory e brake assembly $150 I dont have the ebrake brackets photos posted I will post some soon. the steering arms posted are for 1st gen f body. we are in the final stages of finishing up our 2nd gen spindle and steering arms.
Luke Mau
L & H Kustoms
Old 01-07-2010, 06:37 PM
You guys are making some beautiful parts.
Old 01-07-2010, 06:42 PM
lhkustoms's Avatar
Thanks Wayne we strive to provide the best parts available. No point in making something that isnt functionable and doesnt look good. We are trying to combine both but functionality will always come first.
Luke Mau
L & H Kustoms
Old 01-08-2010, 07:38 PM
Thanks Luke. Get back to me with pictures of the rear brackets with parking brake provisions when you can. PM me if you have to. I have a complete pair of rear C5 brakes. I just need brackets to mount them to and am looking into the different options.
Old 01-08-2010, 11:03 PM
Probird Probird is offline
I have a question on the steering arms. Any provisions built in for more tire clearance when using 2" drop spindles? Like where they moved inward a little to allow for proper back spacing on an 8" rim?
Old 01-09-2010, 12:02 AM
lhkustoms's Avatar
Well the only provision built in are that these are designed after the highly sought after "short" style steering arms. when used with the long pitman arm it will give you the quickest ratio you could get with a factory steering box.
Luke Mau
L & H Kustoms
