Old 01-16-2010, 01:56 PM
aussiebj's Avatar
aussiebj aussiebj is offline
I took advantage of the nice day and pushed the car outside for some pics..hopefully it will be off to the body shop in three weeks...here ya go...
Old 01-16-2010, 05:38 PM
65 347's Avatar
65 347 65 347 is offline
looks good, can't wait to see this finished
Old 01-24-2010, 03:16 PM
aussiebj's Avatar
1-24-10....well the car is finally all together...worked on the inner structure under the rear seat..shaved the door handle on the pass side...finished up the trunk sheet metal and sat the tank in there.....removed the rear to finish welding it up and make some gussets for it as well..now for underneath clean up ,seam seal and get it ready for the Lizard skin undercoating...here are som pics....
under seat in work
and welded up
Fuel Tank in
Rear end gussets
Old 01-24-2010, 03:21 PM
aussiebj's Avatar
some more pics
Pass Inner fender in
Pass door shaved
Old 01-24-2010, 03:25 PM
aussiebj's Avatar
Here are some pics just to show that u dont need high tech tools to build a car this is what i use
Cardboard flat sheet metal and Hand tools
My high tech bender
Old 02-17-2010, 12:56 PM
aussiebj's Avatar
2-17-10 updates ...the car has been completely taken back apart to finish all the welding..as well as paint for all the indivdual components..the underside is almost ready for the Lizard skin coating..
Here is the underside before paint
Rear end painted and assembled.
Old 02-17-2010, 12:58 PM
aussiebj's Avatar
I also worked on installing the radiator..i bought the biggest radiator i could get
made fill in pieces to clean up the eng bay
had to go down into the frame and box it up.
Old 02-17-2010, 01:13 PM
70rs's Avatar
70rs 70rs is offline
That is a HUGE radiator!
The project is moving along nice.
Eric
Old 02-17-2010, 06:27 PM
Nice progress. The rear end looks great,and that radiator should keep it cool.
Old 02-22-2010, 01:08 PM
aussiebj's Avatar
2-22-10 finished up majority of the interior metal work then seam sealed it and installed Fat Mat sound deadner....working on finishing up all the under carrige metal work getting ready for the Lizard skin coating..this beast will be quite inside..also started the mock up of the side exhaust..check out the pics..
Fat Matt installed
New style side exhaust..
