Old 12-05-2005, 06:49 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Wow, those brakes look massive.
My LS7 69 Camaro
Old 12-06-2005, 06:08 AM
syborg tt's Avatar
Need some advise as i am torn between two fuel delv set up's
1. Stealth Tank with one Aeromotive A1000 Pump
or
2. Stealth Tank with dual in tank walboro pumps
The truck is only going to have 600hp on pump gas and 750hp on race gas. I am aware that i am at the limit of both systems at 750hp.
The truck main purpose is to drive the power tour and to local cruise nights.
marty-mj
Old 12-08-2005, 08:18 AM
black2002ls black2002ls is offline
If given the option, I'm all for an external pump. Keeps from having to tear into the tank if pump problems were to arise.
Old 12-08-2005, 08:27 AM
TravisB TravisB is offline
I would go with the external...however I have heard good things about the internal style staying cooler due to the fuel cooling it!
Old 12-08-2005, 10:36 AM
syborg tt's Avatar
yep i have heard the same about internal pumps. Not really sure what to do.
marty-mj
Old 12-08-2005, 05:41 PM
TEDDYS CAMARO TEDDYS CAMARO is offline
Smile
I have had good luck with Aeromotive fuel pumps. I also am going with a stealth tank with an Aeromotive pump. I am pretty sure if you call Ricks Hot Rod Shop, he can give you all the information that you will need.
Old 12-11-2005, 10:19 PM
syborg tt's Avatar
12-11-05 Update.
Working on a new fuel cell.
Looks like we are going to use the external pumps that I have.
One on each side of the tank meeting in the middle at a "Y" block.
The tank will sit between the new frame rails which is two inches narrower then the old tank ;-(
In order to get a little more fuel capacity the tank is built around a frame support.
Here is what the tank looks like removed from the truck
I want to thank Scott Husner for the Box.
He shipped me the first prototype Sonoma GT cladding in it.
marty-mj
syborg tt's Avatar
New Access cover to the Battery
The New Billet Specialties Battery Tray mounted in the bed.
The Frame had to be modified for the Shock Wave Air Bag.
marty-mj
Old 12-11-2005, 10:20 PM
syborg tt's Avatar
Here is a side view of the bed side glove box.
Here is the prototype GT Cladding the Scott Husner is now Offering - Nice Piece.
The Rear End came apart waiting for the arrival of the new Rear Tires & Wheels.
That's it for this week. I hope to have the wheels by the weekend. If not not a big deal there is still plent that needs to be done.
marty-mj
Old 12-12-2005, 07:15 AM
Smack_talker's Avatar
Smack_talker Smack_talker is offline
Lookin good Marty..Cant wait to see it in person on PT 06.
