Old 02-09-2010, 02:17 PM
Sti_Guy's Avatar
Sti_Guy Sti_Guy is offline
Default MacroPoxy
I used a product called MacroPoxy a 2 part industrial epoxy to seal of the wheel houses on my project. This stuff is what they use to seal water towers with and seems to have incredible duarability. Goes on via a roller or spray can be thinned, or tinted. You can pick it up at Sherwin Williams.
The flash from the camera throws off how uniform it went on with a roller. How ever i would spray it on for the best finish. It can be topcoated also if you need.
The Following User Says Thank You to Sti_Guy For This Useful Post:
colorado80439 (06-16-2022)
  #22
Old 02-09-2010, 04:44 PM
Lenie's Avatar
Lenie Lenie is offline
Originally Posted by 67rstbkt View Post
Have you checked out this build?
https://lateral-g.net/forums/show...ighlight=lenie
I believe that's Raptor bedliner
You are correct. Raptor
Lenie
Old 02-10-2010, 06:58 PM
Default Trojan - Careful
Might be careful with this web site and video guys. (from page 1)
LINK REMOVED
When I ran it - it dropped a file in my documents and setting/temp internet folder that was detected as the JS/Wonka trojan by McAfee. Might want to scan your pc just to make sure.
http://forums.cnet.com/5208-6132_102...hreadID=222466
Jim
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 02-10-2010, 11:30 PM
youthpastor's Avatar
LINK REMOVED
Jim
yep me too!
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
Old 02-11-2010, 09:07 AM
G/A-body's Avatar
G/A-body G/A-body is offline
I used Line-x on my El Camino. I shopped around at several of the shops in my area and found a big difference in price. The shop that did it was the best price and showed the most attention to my needs before and during the process.
Robert
https://lateral-g.net/forums/atta...2&d=1258781355
Old 02-14-2010, 09:19 PM
snackbar snackbar is offline
I went with Line-x and masked and painted the rails. It was a total bizznatch even on a rotisserie! I had something like 6 hours into masking alone. I really liked the way it turned out though and should be bullet proof for a long time. I blasted the bottom with a pretty course grit just to give the material extra bite. You have to be careful with drainage though.
Old 02-15-2010, 09:03 PM
GPR's Avatar
GPR GPR is offline
I use SPI www.southernpolyurethanes.com bedliner on the bottom of cars and inside the trunk in my shop.
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 02-17-2010, 10:32 PM
Chicken Louie's Avatar
Chicken Louie Chicken Louie is offline
Default Not sure about the bed liner?
I have been following the thread and trying to decide which way to go on my car. There is no question that it looks great and is bullet proof. My biggest problem with any bed liner material is the major PIA that is involved in removing it if there is any work to be done down the road or repair due to collision etc. Same comment can be used that the coating hides cracking etc? Can anybody comment on working on it after the fact?
