Old 12-02-2009, 04:25 AM
uppster uppster is offline
Does the style of intake effect the drivabilty of this system, or does the electronics take over? The dual plane intakes are suppose to be for low end/street use single plane for higher rpms. Does this system even care what type of intake is used?
Old 01-20-2010, 01:48 PM
Novelli's Avatar
Novelli Novelli is offline
So we got the Camaro up and going. We had some issues with the system initially, computer took a crap before it was even fired, the supplied fuel pump took a dump after 20 miles. Wasn't to happy at first but it seems to work well now. The car is sporting a 406sbc, big heads, victor intake, big cam, 3500 converter. The car seems to like the set up well. It does seem to get better the more we drive the car, the computer does learn. There is no spits, sputters, or flat spots with the car and it blows the tires off through all gears. I would recomend upgrading the fuel pump from the supplied one to a better quality aftermarket pump or Ricks tank with with an in tank pump. So yeah... it works pretty good.
Old 01-20-2010, 01:52 PM
6spdcamaro 6spdcamaro is offline
if your over 600hp fast makes an upgrade kit for dual throttle bodies up to 1200 hp
Old 01-24-2010, 08:02 PM
g356gear's Avatar
g356gear g356gear is offline
http://www.compperformancegroupstore...stemEZIEFIKits
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 02-15-2010, 08:10 AM
g356gear's Avatar
Dual Quad Option for 1100hp
*Dual Quad Upgrade Kit must be used in conjunction with an original FAST™ EZ-EFIŽ Self Tuning Fuel Injection Kit, part #30226-KIT or #30227-KIT.
• Easy-to-use setup Wizard provides comprehensive walk-through and system tunes itself
• Base EZ-EFIŽ System includes ECU, wide-band oxygen sensor, wiring harness, injectors, throttle body and optional fuel pump kit
• Dual Quad upgrade Kit includes second throttle body, injectors and linkage kit
• Bolts on to ANY engine up to 1000+ hp; ideal for hot rodders looking to increase fuel capacity
Old 02-15-2010, 08:12 AM
g356gear's Avatar
Can anyone recommend a good quality dual quad intake for this set-up?
I was looking at this
http://www.jegs.com/i/Edelbrock/350/7520/10002/-1
Edelbrock Air-Gap Dual-Quad Manifolds feature an award-winning design that incorporates the same race-winning technology that's been used in the Victor Series competition intakes for years. The air-gap design features an open air space that separates the runners from the hot engine oil resulting in a cooler, denser charge for more power. RPM Air-Gap manifolds are modeled after Performer RPM intakes for high performance street power from 1500-to-6500 rpm.
Old 02-15-2010, 01:45 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
That's probably about as good as it gets.
Next step up would be a tunnel ram.
Old 02-15-2010, 04:45 PM
Mike Norris Mike Norris is offline
Supporting Vendor
For folks interested in this FAST EZ EFI or any other FAST product, I am offering 10% off of Summits advertised pricing plus free shipping.
Mike Norris
Mike Norris Motorsports
Raymonds Performance
3828 Clarks Creek Road
Plainfield, IN 46168
407-616-2518
www.mikenorrismotorsports.com
[email protected]
Visit Our Facebook Page
Old 02-15-2010, 08:01 PM
Smitty67 Smitty67 is offline
Default Fast
Mike Norris
Hmm.. If I could only find someone to help tune a Fast XFI??
Old 02-15-2010, 09:07 PM
You Asked for it Steve.................
Check this out boys, Group Purchase in effect
Details here
https://lateral-g.net/forums/show...508#post269508
Frank Serafine
