Old 03-19-2010, 11:22 AM
ironworks's Avatar
Default Attention Tri-5 Chevy guys. Ironworks Do-It-Yourself chassis.
Well Guys I have been working on this project for a while. It is chassis for the Tri-5 crowd that would be sold in both a fully welded kit and also in a do it your self fashion. The chassis goes together just like a snap together model. You slide this tab into this slot and index this part into this part. It is really easy.
The Frame starts out like this. A bunch of laser cut plates.
Then you tack together the entire chassis. You can see some of the many tabs and slots that stick through the plates and interlock to assist in assembly.
The body mounts position themselves in the chassis. It is easy.
After everything has been tacked together. You begin to weld chassis together.
We are currently designing the Modular rack mounts to be able to run 3 different racks, AGR, flaming river, and a Woodward steering rack. The Rear suspension is four link with a watts link. We plan to sell the exhaust and fuel tank mounted in the car. The motor and trans mounts will be adjustable to allow you to mount the engine where you choose.
What I'm looking for are 3-4 test subjects who have medium skills and want to build their own chassis. You do not need a jig fixture to assemble this chassis, and I don't think it is possible to put it together wrong. We plan to sell these kits with a welded rear axle housing with all brackets and axles installed. You just assemble the chassis like a snap together model and bolt on the C6 vette suspension and all the machined suspension parts for the front and rear suspension. With the up coming west coast events I would like to coordinate with test subjects be able to coordinate the builds.
Let me know your thoughts on the product and your thoughts on the do it your self aspect.
Final assembled pics of the chassis will come when we unveil the new product officially at Del Mar next month.
Old 03-19-2010, 11:30 AM
JamesJ JamesJ is offline
Thats pretty cool, will make shipping much cheaper and simpler....
James J.
Old 03-19-2010, 11:49 AM
jy211's Avatar
jy211 jy211 is offline
I got a 56' driver that will be in the project line after I finish my 55'. But I'd be in for a new frame
My brother has a 55' Handyman wagon that is at the start of a build.
So we'd be test subjects if need be.
Old 03-19-2010, 12:26 PM
fleetus macmullitz's Avatar
Neil summed up my thoughts in the first 15 seconds...
Old 03-19-2010, 12:33 PM
Rybar's Avatar
Rybar Rybar is offline
That is killer Rodger, nice work I think you will do well with these.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 03-19-2010, 12:47 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Now, here comes the jealousy question. What about us other GM guys? Any plans to do other cars....i.e. = Chevelles, Camaros, etc? Screw the Mopar guys. Just kidding!!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 03-19-2010, 01:02 PM
ironworks's Avatar
I hope so. These are really nice pieces. We have used the best parts and tried to do some really trick features.( The Rear lower link of the suspension, comes out of a pocket on the bottom of the chassis, That is slick show car stuff. ) We will offer 2 ride heights. And you will be able to run a couple different tire and wheel combo's. It will be able to run 335 rear tires and we are working on finalizing running 275 front tires.
Old 03-19-2010, 01:15 PM
ironworks's Avatar
The Chevelle is in the works, Currently. Should have a roller very soon.
We plan to have a few others in the works.
The Camaro market is pretty saturated with alot of great products. So it might be a while. I would do a tube chassis Camaro one before a bolt on Camaro subframe.
Old 03-19-2010, 01:53 PM
Musclerodz's Avatar
What kind of reinforcing does the upper a-arm mounting plate get? Picture above shows none. I am very interested as we have a 56 HT to do as soon as I find the right candidate.
Mike Redpath
Musclerodz & Customz
facebook page
Old 03-19-2010, 02:01 PM
ironworks's Avatar
There is a strip that goes around the top of 1/4" x 1" that goes in the opposite plane to the upright. We have to form these by hand they are not machined. Plus the shock mount tabs and inside crossmember help reinforce the plate that same plate.
