View Poll Results: Which rearend should I buy
12 bolt w/ 33 splines 61 62.89%
9in 36 37.11%
Voters: 97. You may not vote on this poll
Old 04-15-2010, 10:42 AM
Bonebuster29 Bonebuster29 is offline
Default 12 bolt w/33 splines or 9in rearend with g-link
Which one should I buy if I am buying a brand new rearend? AND WHY
The cost is only a difference of like $150 and I had had mixed opinions...
My camaro will be pushing around 450-500hp
Old 04-15-2010, 11:23 AM
ElkyZO6 ElkyZO6 is offline
12 bolt all the way. It also takes less power to turn.
Old 04-15-2010, 11:51 AM
Rybar's Avatar
Rybar Rybar is offline
I am in the exact same boat as you. Going with a Moser 12-bolt.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 04-15-2010, 01:17 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
I went with the Moser 12 bolt with 33 spline axles. Here's pictures after we welded the brackets on. it has since been painted.
Chris
Old 04-15-2010, 01:48 PM
Rybar's Avatar
That looks sweet Chris, same is what I'm going with. What width did you go with what are your wheel specs?
1969 CAMARO RS
Old 04-15-2010, 01:55 PM
33 splines for 450-500hp is more than plenty. I have a 12 bolt but I don't think it's an earth shattering decision. I've been happy with my true trac so far.
Old 04-15-2010, 08:33 PM
ItDoRun's Avatar
My wheels are 18x11.5 with 5.4" backspacing. My rearend width from axle flange to axle flange was 54".
I set my wheels and tires under the car and dropped a plumb bob from the 12 o'clock position on the wheel lip then set the outside edge of the tire 1/2" from the string. I have plenty of room on the backside...maybe 3/4"-1". I also trimmed the lips down to 5/8" wide for extra tire clearance. I may could have went 1/4" to 1/2" wider on the rear end, but everything seems to look dead on after mocking it up. I hope to have it on the ground next weekend (for the first time in 2-1/2 years), so I'll study it better then.
Remember, you can always add a small spacer, but it's a pain to cut the rear end again. Measure 50 times, then call Frank!
Chris
Old 04-15-2010, 08:34 PM
ItDoRun's Avatar
Good to know. I was hesitant about the limited slip at first.
Chris
Old 04-16-2010, 06:58 AM
67bird 67bird is offline
If your not set on changing the gears out, go with the 12 bolt.
Old 04-16-2010, 07:05 AM
It's predictable in a racing enviroment. You'll be happy with it.
