Old 05-17-2010, 09:55 PM
I would also expect the FAST EZ EFI to continue to tune itself and bring the A/F ratios in better and better. They are "set" in the programmer at 12.8 WOT - and the pull I posted above - shows 13.24 @ 4600 -- a little lean for torque production. This will tune itself as the ECU builds better VE tables. At 6000 rpms it was making 12.52 A/F
When Tom Nelson and I discussed this build - he said that the 8 stacks tend to add air so quickly - that it's hard for the fuel to catch up. I'm sure that having watched how quickly the ECM learned and adjusted from first start up to making some pulls -- that it will fatten the A/F as it learns more. But we felt - since the motor would run and behave differently as installed in the Nomad - rather than the dyno - there was little point in in continuing to flog the motor just to bring these to perfection.
The EZ EFI goes into learn mode as soon as the ECT hits 140* -- so every time you drive - it's honing in on the perfect A/F ratios...
Old 05-17-2010, 10:02 PM
Here's something else I was impressed with - and again - given the little amount of actual time to have the FAST EZ EFI learn...
Check out these EGT's
Starting with #1 @ 5000 RPM
1146 1045 1078 1050 1013 1087 1052 1090
Old 05-17-2010, 11:07 PM
It's definitely making some killer torque. It will be a great driver that will move that Nomad with ease.
Old 05-18-2010, 08:55 AM
BBC69Camaro's Avatar
Greg nice flat torque curve, seems like you had the same goal I did when I choose my setup Been thinking about EZ-EFI as well, thanks for sharing!
Old 05-18-2010, 09:25 AM
I just posted a new thread -- FAST EZ EFI under the EFI section
I'm 100% positively sold on this system -- PROVIDED you do your homework and supply some good vacuum signal for the MAP sensor etc. Super simple - super effective!
Old 05-18-2010, 11:49 AM
Hey Greg, you do anything with your fuel system for the setup?
Old 05-18-2010, 11:53 AM
Cart>Horse
Old 05-18-2010, 12:46 PM
No -- I already had EFI - so no changes - only change was the "rebuild" - intake - Computer.
This system does require a vacuum referenced fuel pressure regulator - and a return line just FYI.
