Old 06-27-2010, 10:54 PM
johnnymac46's Avatar
johnnymac46 johnnymac46 is offline
Default How big can I go?
I am going to be installing hotchkis upper and lower control arms with 2inch drop springs on my stock subframe of a 68 camaro, can anyone tell me what size wheel and tire combo i can get away with?
Old 06-28-2010, 09:56 AM
JayR JayR is offline
Lateral-G Supporting Vendor
Whether it's stock height or on Air Ride, it will safely hold 8s up front and 9s in back.
Old 06-28-2010, 10:57 AM
I will be doing DSE tubs in the rear and plan to run as big as i can get and still clear. is that an 18x8 or 17x8?
Old 06-28-2010, 11:00 AM
JustinB's Avatar
JustinB JustinB is offline
If you are going to be mini tubbing with the DSE tubs, a 17-20x12 with a 335 rear tire is the way to go.
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
Old 06-28-2010, 11:08 AM
how big of a tire can i run on a 18x8? Im trying to find some prices so i know how much im gonna have to dip into my retirement...
Also any suggestions on a good streetable set of tires?
Old 06-28-2010, 12:02 PM
JustinB's Avatar
Assuming you would use the 18x8 for the fronts, a 245/40/18 is what we would use. For the rears, if you wanted to keep cost down, run a 18x10 with a 305.
Justin Butler
Old 06-28-2010, 03:03 PM
Those are 18x8s on both cars I posted and Justin has you covered on your other questions.
Old 06-28-2010, 04:43 PM
SLO_Z28 SLO_Z28 is offline
Nitto NT555 and Sumitomo HTRZ3's are my favorites.
Old 06-28-2010, 07:55 PM
Here are a few we did I found real quick
18 X 8 and 18 X 12 Forgeline SP3P
245/40/18 front and 335/30/18 rear BFG KDW TA2
18 X 10 and 18 X 12, 275/35/18 and 335/30.18 R BFG KDW TA2
18 X 9 and 18 X 11.5, 265/35/18 and 315/30/18R Michelin PS2
19 X 11 and 20 X 13, 295/30/19F and 345/25/20R Pirrelli P Zero (custom frame)
Frank Serafine
Old 06-29-2010, 06:44 PM
Thanks everyone for all the help Ive got a pretty good idea what im gonna run now
