Old 08-05-2010, 04:32 PM
almcbri's Avatar
almcbri almcbri is offline
Originally Posted by Pantera EFI View Post
The information provided is limited, though the stock GM Camshaft is on a 117 C/L.
Your stated cam 224/230 111 Lobe Center could reduce engine high RPM performance a great amount.
Low speed performance would be terrible with that camshaft.
My choice would be a 224/230 with a 118 Lobe Center.
I would also change the injectors, we use Denso 470cc injectors that will idle BETTER than stockers.
The OVER size pump could "push" ALL to oil out of the pan.
Lance
I haven't purchased the cam kit yet. The guys at thunder racing said their 230/224/111 cam was excellent with a 6 speed set-up. I am not an engine guy at all. I just want something that I am going to get good performance out of and not shake the car to death. Something mild is what I was shooting for.
I will check out the injectors. Thanks. AM
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
