Old 08-11-2010, 05:17 PM
conekiller13's Avatar
conekiller13 conekiller13 is offline
How much weight does that add? Do You think the car will be close to 2700lbs minimum for the class? What does noise and heat matter if it's only going to be driven 50-60 seconds at a time? Or is it still going to be street legal?
Dan
Old 08-11-2010, 05:31 PM
73CPCAMARO's Avatar
73CPCAMARO 73CPCAMARO is offline
The weight gain is minimal. The car will weigh about 2600 lbs when it is completed. All the bolt on panels are fiberglass (doors, hood, fenders, nose, bumpers, deck lid). Because I am running a 416 cubic inch motor and 18" x 12" wheels, the car must weigh 3100 lbs. I will be adding about 500 lbs of lead / steel to the floor and cage behind the rear seat. All very low and centered weight. And yes, this will be a tricked out CP Camaro with lights that I will occasionally drive on the street. People say I am crazy, but, I have a vision and I am seeing it thru.
Brian Hobaugh
1965 Corvette
1973 Camaro
2003 Z06
Old 08-11-2010, 06:58 PM
coolwelder62's Avatar
Race car's that are driven on the street are coolest car's.
Old 08-12-2010, 07:42 AM
That's cool. That was My original plan for My Chevelle but due to budget cuts it looks like the race car side is winning
Dan
Old 08-12-2010, 09:20 AM
deuce_454's Avatar
does the weight have to be fixed? the mercedes DTM class race cars have their weight mounted on a slide so the weight bias can be shifted... (the 2008 cars had them hydraulically operated to change bias for braking, acceleration and turns)
Jake: Hit it.
Old 08-12-2010, 12:31 PM
73CPCAMARO's Avatar
Yes it does. We have a plan for the weight addition that should work very nice. I will show it when it is added.
Brian Hobaugh
1965 Corvette
1973 Camaro
2003 Z06
Old 08-12-2010, 03:08 PM
Is it done yet, Is it done,Is it done yet. Can't wait any longer (PLEASE) paint it tonight.
Old 08-12-2010, 03:10 PM
Are you going with the 18" primarily for looks or because of the brake package? 16" seems to be the class norm. I haven't decided if I want to down size My current Bear brakes and go to 16" wheels with the de rigueur Goodyear slicks, or keep the brakes and go with the bigger wheels. The true racing slicks get obscenely expensive in those sizes as can be the cost of big wheels. Guess it will depend on if I can get the weight down or not. Decisions, decisions.
Dan
Old 08-12-2010, 04:07 PM
73CPCAMARO's Avatar
I am going with 18" x 12" rears with a 345-35-18 Hoosier A6 and 17" x 12" fronts with 335-35-17 Hoosier A6. The car will be able to run 16" x 12" with Goodyears if needed. Tire technology has come so far the past few years. The A6 is just as fast or faster than the Goodyears. Both tire packages are stupid expensive.
Brian Hobaugh
1965 Corvette
1973 Camaro
2003 Z06
Old 03-22-2011, 02:32 PM
PonchoJohn PonchoJohn is offline
Brian,
Have you thought about adding weight inside the rockers themselves? That's a pretty low CG, I would think.
Oh yeah, Awesome build!
