Old 01-09-2006, 07:16 AM
lil427z's Avatar
lil427z lil427z is offline
Thumbs up
like to no the $$$$ it will coust .
rick k
Old 01-09-2006, 07:23 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Hard to say what it will cost, but you know it will HAVE to be in line with the Mustang. They can't price themselves out of the market.
To me, the BIG question is.... can I get it with an LS7?
My LS7 69 Camaro
Old 01-09-2006, 07:30 AM
rockdogz's Avatar
rockdogz rockdogz is offline
The Z06 flagship engine? I don't see how they would allow that... don't get me wrong, I would be all over that but I think the chances of that are slim to none.
-Tom
camarorestoration.com
Old 01-09-2006, 07:32 AM
trapin's Avatar
trapin trapin is offline
Price will be in line with Mustang and Challanger.
Drivetrain? Probably LS3, 6 speed gearbox.
Tony Rapin
The Pigeon Forge Project
A 1968 Pro-Touring LS1 Camaro.........and why not?
XcYZ's Avatar
I hear you, but it would be cool if they did a very limited run - like a ZL1.
It doesn't matter to me I guess, there's no way I could afford that anyways.
My LS7 69 Camaro
Old 01-09-2006, 07:40 AM
mdprovee's Avatar
mdprovee mdprovee is offline
I like it...if they make them at a good price I would be in line to get one.
The only thing I dont like is that the grille is too pointed and doesnt match the front edge of hood. I think it would flow better with the grille at the same angle as the front edge of hood.
Mike
Old 01-09-2006, 08:16 AM
rockdogz's Avatar
What's an LS3??
-Tom
Old 01-09-2006, 08:28 AM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
Couldn't some clever dealer order an COPO with LS7?
Or it might be LS8 when it comes out.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
www.protouring.se www.carphotos.se
Old 01-09-2006, 09:42 AM
trapin's Avatar
Originally Posted by rockdogz
What's an LS3??
Exactly.
Tony Rapin
Old 01-09-2006, 10:00 AM
Diognes56's Avatar
Diognes56 Diognes56 is offline
Found this on Cheers & Gears :
Courtesy of Cheers & Gears, the official specs are:
Wheelbase (in / mm): 110.5 / 2806
Length (in / mm): 186.2 / 4730
Width (in / mm): 79.6 / 2022
Height (in / mm): 53 / 1344
Track (in / mm): 63.8 / 1620 front; 63.3 / 1607 rear
Engine: 6.0-L V-8 LS-2, 400 hp / 298 kw, with Active Fuel Management™
Transmission: six-speed manual T56
Suspension: four-wheel independent: MacPherson strut front, multilink rear, progressive rate coil springs, gas-pressurized dampers
Brakes: four-wheel disc, 14” rotors with four-piston calipers
Wheels: cast aluminum, 21” front, 22” rear
Tires: 275/30R21 front, 305/30R22 rear
Other links of interest:
Fastlane Blogs
Chevrolet Performance
AutoWeek
More Pics and the Competitors
Here is a pic of the rear for those who have not seen it and also a profile view, interior view, and engine view: (The top three pics are from AutoWeek and the fourth is from Cheers & Gears )
David
