Old 09-03-2010, 09:07 AM
ricer ricer is offline
Default DSE mini tub kit ????
Has anyone ever used caltracs on the mini tub kit? Not sure if it is even feasible with the offset shackle but just looking into different options rather than the AME/DSE 4 link systems
(looking to make alot of trips to the dragway so need something that can take the abuse and plant the power)
Old 09-03-2010, 10:18 AM
XcYZ's Avatar
XcYZ XcYZ is offline
I don't see it being a problem at all.
My LS7 69 Camaro
Old 09-03-2010, 10:24 AM
my main concern is the shackle bending i guess. The motor is being built and should be making north of 1700hp on race setting and that much pressure/shock load being applied to the offset shackle i can see it bending.
the car really needs to be backhalved but i want to retain the back seats for the kids when taking it out on a cruise. So i need something that is strong enough yet compact, so my options are limited.
so needless to say this is more of a drag car but occassion street use (but with the "pro-touring" look to it)
Old 09-03-2010, 10:43 AM
XcYZ's Avatar
Wow, 1700hp. Now I understand why you have concerns!
My LS7 69 Camaro
Old 09-03-2010, 04:28 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
I think that if you are going with that much power you need to go tot a 4 link just my .02. Also just curious what kind of car are you putting all this power into?
Old 09-04-2010, 06:25 AM
yeah the 4 link is the right way to go, but i want to retain the back seats so that is my issue. The car will be a cruiser for the first couple of years until the kids get older then will get the whole chassis redone (25.2 cert). So for now i am looking to do it as a "pro-touring" style car that is why i joined the site to do some research and get some opinions on it.
the car is a first gen firebird
Old 09-04-2010, 11:52 AM
aronhk_md's Avatar
aronhk_md aronhk_md is offline
The problem here is the fuel tank. If you just go to a custom fuel tank (since you are going to want either a cell in the trunk or a narrower tank underneath with a sump to get enough flow for the BIG pump you'll need...I know as mine puts out around 1100 hp) just relocate the shackle mount points at the rear inboard.
1973 Trans Am
73 455 SR block, ported 6x-8 heads, solid cam, Victor intake, 830 CSU carb, aluminum rods
oh.......did I mention the 77mm Garrett turbo and methanol injection?
886 hp at the rear wheels, 1064 at the flywheel (calculated)@5500 rpm, before the methanol injection was added. Thank you Mark L...
Old 09-04-2010, 03:18 PM
98ssnova's Avatar
Dude the seats are easy just modifly the frame you wont even see the them when you are done.
Old 09-06-2010, 03:09 PM
DENALI DENALI is offline
"F-Bomb" used the tub kit with caltracs their leaf springs with no problem. Dont see why you would have any problems either. Good luck!
Old 09-07-2010, 06:14 AM
I am going to put the tank in the trunk and either have the lower portion completely hang through it or just have the "sump" hange through it. I haven't decided on a pump yet, if i go electric it will be a weldon, if i go belt driven will be a Waterman
I have seen/heard about that car but never read into all the details, i will take a look at it. Thanks for the headsup
