Old 10-02-2010, 05:34 PM
Check to see if you have SEPARATE hazard flasher. If so -- same problem - you'd need to replace it with a LED flasher.
You have a aftermarket wiring system... so see if there's another flasher - or circuit that is separate from the turn signals. Also - check to see if you have a fused flasher circuit.
