Old 07-06-2008, 01:13 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Default 465 hp 383 SBC For Sale
I have a very nice 383 for sale. The engine, which was used for about 1,000 miles, is balanced and blue printed; 010/020 block, cleaned, magged, honed and zero decked; billet splayed four bolt main caps installed on three center main bearings and line bored; 4340 Eagle 3.75" forged crank; 4340 Eagle 6.0" forged "H" Beam rods; SRP –16cc forged dished pistons; Clevite 77H bearings throughout; Melling high volume oil pump with welded on pickup; Moroso trap door 7 qt. oil pan and windage tray; Crane 119841 hydraulic roller cam (0.539"/0.558", 296/304;112 LSA), double roller timing chain; Comp Cams Pro Magnum retrofit hydraulic roller lifters; Comp Cams pushrods; Comp Cams Pro Magnum 1.5 roller rockers; AFR 195 aluminum heads angle milled by AFR to 59cc chambers and assembled by AFR with + 0.100 valves and AFR 8032 hydraulic roller valve springs; Edelbrock Vic Jr. intake; Demon 750 Carb; Fluid Damper harmonic balancer; MSD billet distributor; aluminum timing gear cover and polished aluminum valve covers; professionally assembled by JMS Racing Engines in Monrovia, CA. Dyno'd at 465 hp at 5,700 rpm; 464 ft. lbs. of torque at 4,500 rpm.
This engine is ready for a turbo or supercharger with a swap of 72cc or so aluminum heads. The bottom end is more than stout enough and the -16cc pistons will get you into the right static CR range for the boost. As it sits, the engine is 10.3:1 static CR and about 7.5 DCR.
$4,500 OBO (which is a smoking deal - just add up the parts). I need this engine gone. Local pickup in Southern California. The engine is in Altadena, California. The headers are NOT included.
Old 01-25-2010, 10:29 AM
JethroSeven's Avatar
JethroSeven JethroSeven is offline
Default 383 for sale
Hello, i'm interested in this for my '68 camaro and in SoCal. i can be reached at 310 218 8007 if you still have it. thanks J7
Old 01-26-2010, 06:26 PM
jwalk's Avatar
jwalk jwalk is offline
I would jump on this if I had a little more money lying around. If you still have it in a month I might have enough.
Old 01-26-2010, 06:41 PM
Mkelcy's Avatar
LOL, if I still have it in a month, I'll be giving you a call.
Old 01-26-2010, 08:31 PM
jwalk's Avatar
sounds good
Old 01-29-2010, 11:25 AM
Mkelcy's Avatar
Bump.
Old 10-09-2010, 12:33 AM
madcarson madcarson is offline
Default Afr
want to sell the head ?
Old 10-14-2010, 11:35 PM
sn75's Avatar
sn75 sn75 is offline
That engine is in my car now
'72 Chevelle - ZL1 LSA, BTR Stage 2 cam, ATI lower pulley, 4l80e, Speartech harness, Viking coilvers, Baer brakes, UMI suspension components, Rick's S/S tank/VaporWorxs, Hooker Blackheart longtubes and 3" S/S exhaust, Vintage Air, Corbeau seats, Billets Specialties 18" wheels........
New Project: ‘70 Chevelle, RS Chassis, LSX 376 B15
Engine, BTR Stage 3 PD cam, Whipple 3.0, Holley EFI, manual trans and much more
