Old 11-29-2010, 06:10 AM
AM.MSCL's Avatar
AM.MSCL AM.MSCL is offline
What is 5th gear ratio?
Hydraulic throwout? included?
Bellhousing, clutch, pressure plate included?
Crossmember included?
What car was it meant to fit?
Did you get to test drive the car it was in before being pulled out to make sure it was ok?
Ray
Old 11-29-2010, 05:23 PM
NvrDun71 NvrDun71 is offline
Ray
Ray,
5th gear ratio is .64. I am just selling the trans, no additonal parts are included other than the trans mount and speedo cable. This will bolt up to any traditional sbc, bbc, or LS motor if desired. I was not able to test drive the trans before purchase, but I have absolutely no reason not to believe the seller of its conditon or mileage. If you have any additonal questions don't hesisate to ask. I will have some pics up soon.
71' Nova - LY6, T56
Old 11-30-2010, 06:40 AM
AM.MSCL's Avatar
Please post some pictures of everything that is included and I can make a decision from there. Or if you need to email them then send to am.mscl at um . att. com
Ray
Old 12-05-2010, 08:14 PM
Pics added
71' Nova - LY6, T56
Old 12-09-2010, 08:23 PM
All PM 's responded too, Offers Welcome
71' Nova - LY6, T56
Old 12-10-2010, 05:25 AM
Roberts68 Roberts68 is offline
Default YOUR PM box is full again
It is probably common knowledge to the guys looking at these awhile but what shifter position is optimal for a First Gen Camaro?
A friend of mine has a T56 in his '68 with the shifter in the factory console. I would want a different stick but would definitely like to have the same trans tunnel positioning.
How does that rearmost position fit in the 1st Gen Camaro? Any idea?
Robert
Old 12-10-2010, 07:08 AM
g356gear's Avatar
g356gear g356gear is offline
Robert
I believe Hurst Driveline conversions has their blackjack shifter available for use with the TKO's that posiitions the shifter perfectly in the stock console.
http://www.hurst-drivelines.com/inde...230&Itemid=166
Hurst Blackjack Offset Shifters
Hurst Blackjack Shifter for Tremec TKO & Tremec T56 Magnum Transmissions
When installing a Tremec TKO 5-speed or T56 Magnum 6-speed into a classic car, achieving shifter stick positioning in the stock shifter location is a priority for many applications. In addition to achieving correct shift stick positioning it is equally important to use a high quality shifter that is built to last and that has a good shifting feel. In other words a shifter that positions the shifter stick in the correct location but is poorly built is not an adequate solution. With these requirements in mind we have engineered the Hurst Blackjack shifter. The Blackjack shifter is direct bolt on unit that requires no modification to the transmission.
•Factory fit in stock center consoles
•No console modifications required!
•Short throw design
•Billet aluminum construction
•Low profile design for easy fitment
•360* Delron pivot ball
•Genuine Hurst quality
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 12-11-2010, 11:33 AM
Robert
The rear most shifter position should fit within a stock console without issue using the proper offset shifter like posted above. PM's cleared BTW
71' Nova - LY6, T56
