Old 01-08-2011, 03:50 PM
Motorcitydak Motorcitydak is offline
Thanks for the replys guys.
Im resistant to use a transaxle because then that located the engine way forward in the car. I want it actually to end up being mid engine. Im planning to cut the firewall and push it back around 10 inches. Im not running anything under the dash board (HVAC) so I figure why not put the engine there.
i was concerned with cutting the closed knuckles open for strength reasons, I just was not sure if they were the same thing except one of em was cut by the factory and one was not.
I still want to run a 5x4.5 bolt pattern so any hub that I run, Im planning to have redrilled since most chevy parts ran 4.75.
Is the geometry of the s-10/blazer knuckle good enough to run in a car like Im building? Id really like to get the best and lightest parts I can afford.
Im not trying to use any special one-off parts for this build if I can afford it. The STS diff is made by getrag but Im not sure what size the ring gear is. The one I found has a 3.23 which should work out great for me.
The trans I want to use is the 545rfe 5 speed auto that comes stock behind the 5.7 Hemi which I also want to run. I have one sitting around rite now from a 4x4. Im trying to just bolt a gutted transfer case to it to send power to the front. The trans is rather large and heavy but at least all that weight will be behind the motor and very low to the ground, helping out weight distribution.
The car Im building is a '68 Dodge Charger. Its pretty much a bare shell rite now so I have a blank canvass to build from. Im obviously not doing a typical resto on it. This car is getting to most ridiculous parts I can think of. I have a 3 link rear full floating 9 inch already in place minus coilovers, watts link and sway bar. I just bought lower control arms which are chromo pieces from a nascar, uppers will come from the same genre. I want it to be built to excess in terms of performance. I want it to be an engineering exercise I can drive.
Ive seen that AWD Vette, it looked just a vette with the front end of an S-10 frame welded onto it. Its neat but not what Im going for. Obviously I want it to be as light as possible and have the best weight distribution I can build. The STS front diff is a very compact unit which will not take up much space and have minimal weigh impact. Then just the CV shafts that plug into what ever knuckle/hub I can figure out to run. One good thing to see is that the vette had iirc a 7.2 inch front ring gear which was able to live with all that power.
Ill look into those parts from coleman, thanks for the tip. The motor Im running will have 4-500hp/tq, I figure that the front end parts should be able to live with half of that. I see FWD cars with 300hp w/o many problems.
Old 01-08-2011, 04:20 PM
ProTouring442's Avatar
Isn't there an AWD version of the Chrysler 300? Perhaps there would be parts there worth looking into?
Shiny Side Up!
Bill
Never met a man with real talent who felt the need to deride the efforts of other.
Old 01-08-2011, 04:51 PM
Yep, there is. That was my first place to start looking for parts. Ive been trying to find em for it and for the life of me, I cannot. I do know a few things about it. The front diff goes thru the oil pan. Also, the 5.7 Hem in the LX platform(300, charger, est...) gets a mercedes transmission. A Wa580 or something like that. Its overly complicated and not conducive to modifications or being swapped into some other platform. From what I can find, the transfer case in those cars may be the same as the ones in the SRT-8 jeep. A NV147. That is also an overly complicated piece that will not bolt up to my transmission. I need a NV231 or something similar to use in my car
Old 01-08-2011, 07:17 PM
Here is the STS diff im getting
Like I said, its very compact and will be easy to build around/into the car. Im getting the driveshaft with it and will still have to figure out what CV shafts to run. Most likely I will just do the STS shafts and have to get em modified for lenght
Old 01-10-2011, 11:03 AM
exwestracer's Avatar
exwestracer exwestracer is offline
If finding parts or using that Getrag diff proves difficult, keep in mind that you can use any IRS rear diff by running it upside down (high pinion). Some factory 4wd applications actually used this setup without any oiling problems.
Not sure what you mean by cutting open a closed knuckle... If you're referring to the 4wd front axle "closed knuckle", they are NOT designed to run open. They would be full of oil or grease, and have an open CV (commonly known as a Birfield joint) at the steering axis. I don't think you could get a closed CV type 1/2 shaft in there without some MAJOR re-engineering. That's why I like the S10 hub for this kind of thing...just bolt it on and go.
Ray Kaufman-Wyotech chassis fab instructor
Custom suspension design and consultation.
(Now 2) Big Block asphalt supermodified ('cause too much is never enough...)
Old 01-10-2011, 06:32 PM
Originally Posted by Motorcitydak View Post
What I do not like about them is that the upper ball joint is built into the knuckle. I want to run nascar type arms that have the ball joints in the arms.
couldn't you just fabricate a plate that bolts in place of the upper ball joint with a tapered hole to fit the upper ball joint that is on the c6 knuckle?
Old 01-12-2011, 11:06 AM
It looks like Im going to have to do that. I was about to buy a c4 knuckle but the hub is held on with a rectangular 4 bolt flange and they are different front to rear. On the c6 parts, they used just about the same hub front and rear. The knuckles have a much larger hole in the center and the hubs use a triangular 3 bolt patter. Im not completely sure on this one, but I think I can take the front STS hub and just bolt it rite into the c5/c6 knuckle. They both appear to be the same size and bolt pattern but I am not positive. That would solve the hub and knuckle issue so then I will just have to figure out something else to do for the UCA.
Im thinking I can use a UCA with the bolt in ball joint. Then maybe sandwich that with 2 pieces of 1/4 steel? AFCO makes em with a 3/8 thick bolt plate so I could also to weld in a 3/8 circle to one of the sandwich plates. That would give the ball joint 7/8 of steel in the UCA to hold it in. Keeping in mind that the UCA does not see all that much force anyways, I think that would be more than enough.
Old 01-13-2011, 10:21 AM
Try to find a UCA that has the tubes running out past the ball joint centerline, rather than the plate hanging off the end. You don't need such a massive plate if the side loads are going straight into the tubes.
Old 01-13-2011, 02:31 PM
Who makes control arms like that? I just looked at the AFCO site and was going to get em thru there. Is there somewhere better?
Also, the AFCO ones have a 3/16 flange. Not 3/8 like I thought for some reason. I still could use 2 1/4 plates on that and the 3/16 in the middle giving the ball joint 11/16 of steel to ride in
Old 01-14-2011, 11:56 AM
Just a couple examples.
http://www.howeracing.com/p-7564-cro...pe-4-bolt.aspx
http://www.detroitspeed.com/1967-196...30101-uca.html
I'm sure there are others out there.
(Actually I just went back and looked at AFCOs arm. They are a better design than they used to be. I haven't dealt with theirs in about 10 years. Those shouldn't need a lot of reinforcing either...)
