Old 03-01-2011, 04:52 PM
zcrz zcrz is offline
Just got my EZ EfI today....ready to install now
Old 03-01-2011, 05:27 PM
ccracin's Avatar
ccracin ccracin is offline
Originally Posted by 6D9 View Post
I wonder if they plan to make a EZ-EFI that would support 650+ HP??
You can probably get to 650 with one TB. Our engine in the video made 614 at only 43psi fuel pressure. You can go up from there. I think much past 650 and air will be a problem. The dual TB's are in order.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 03-02-2011, 04:14 PM
6D9 6D9 is offline
Thanks Chad for the info!
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
Old 03-05-2011, 09:55 AM
g356gear's Avatar
g356gear g356gear is offline
I think they have a quad system option that addresses that.
Correct...supports up to 1000hp with dual quad option.
*Dual Quad Upgrade Kit must be used in conjunction with an original FAST™ EZ-EFI® Self Tuning Fuel Injection Kit, part #30226-KIT or #30227-KIT.
• Easy-to-use setup Wizard provides comprehensive walk-through and system tunes itself
• Base EZ-EFI® System includes ECU, wide-band oxygen sensor, wiring harness, injectors, throttle body and optional fuel pump kit
• Dual Quad upgrade Kit includes second throttle body, injectors and linkage kit
• Bolts on to ANY engine up to 1000+ hp; ideal for hot rodders looking to increase fuel capacity
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 03-05-2011, 03:38 PM
yep, and you can make it look like two carbs if you spend a little time hiding the harness...............
Old 03-05-2011, 06:09 PM
ccracin's Avatar
Very nice Jody!
Chad
Instagram - @cctek
Old 03-09-2011, 08:36 PM
So Jody -- being the old tuner boy that you are.... did you fire that dual quad bad boy up - and tell me how well it ran and how quickly it ran "well". IF you've fired it up yet.
Wished I'd have had time to see you when I stopped at Charleys the other day - it was rather spur of the moment - since I'd finished up with the real estate agent "early" so the stop was unplanned.
Old 03-09-2011, 09:19 PM
first thing I did when the car got here was to get it up and running before changing the wiring around. The car fires instantly, faster than any EFI combo I've ever been a part of. I can't say as far as driveability yet, but so far this system really works well.
Old 03-09-2011, 09:28 PM
Good to hear!
My Nomad fires before it can make a full revolution. Just instant like a new car.
They really seem to have a winner in this system!
Old 03-09-2011, 09:51 PM
Sieg's Avatar
Sieg Sieg is offline
Great looking motor Jody. Definitely like the positive feedback the Fast-EZ-EFI system is generating.
