Old 03-30-2011, 12:02 PM
The WidowMaker's Avatar
I want my bumpers black, so i have thought about using some tuff chassis epoxy that will be easier to touch up because it will chip no matter what you use.
spi is now shipping their black epoxy with added uv protection. it seems this has been the downside to epoxy since it will turn "chalky". it may be a good solution.
i also had this decision to make, but since i cant get a powdercoater to match my color i have to do it in paint.
"The WidowMaker"
Old 04-07-2011, 08:36 AM
g356gear's Avatar
g356gear g356gear is offline
I did mine in powdercoat and then paint. Welded in the bumper mounts and shaved the bolt heads. Came out perfect.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
