Old 04-13-2011, 01:35 PM
boostin05blacks boostin05blacks is offline
Originally Posted by Rybar View Post
I never used those pre-load plates either with my S&P mounts. Same problem. But I also trashed two sets of the poly mounts. Not sure why. Changed to solid this year.
Motor looks great in there.
Cool man thanks for the info. Thats what I wanted to hear. My dad pointed out another thing I need an opinion on. When we where putting the motor mounts onto the actual frame the one way they hang over the edge, but the other way they sit on the frame touching it all the way. Seeing the way it hung over the edge I said it cant be that way. My dad though it was. We put it the way I thought and he emailed me today saying he was right...see the picture below. Can someone confirm which way they sit? Does it matter?
Old 04-13-2011, 03:44 PM
Rybar's Avatar
Rybar Rybar is offline
Mine are also like this.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 04-13-2011, 07:34 PM
You must be excited to see the motor in there. It looks great. My engine stands hung off like that too.
Old 04-22-2011, 08:07 AM
Got my oil pan in from mast and it looks good. It will be installed this weekend and I will be painting the floors with por-15. More upates coming..
Old 04-25-2011, 07:08 AM
So I didnt get over to work on the car as much as I wanted to this weekend. My dog has been pretty sick but she seems to be doing a lot better. I did get the oil pan installed but no painting, maybe next weekend. I looked over the internet for tourqe specs on the pan and pickup and came up with the following on top of the pictures. if any of this sounds wrong please let me know.
Heres some pictures.
I torqued the bolts that hold the pickup mounts on the deflector pan to 28 lb-ft
The pickup tube to the pump was torqued to 9 lb-ft or 106 in-lb.
Here is the view from when I first put the bolt in. It made me uneasy seing it that close to the chain so I went to the hardware store and got a shorter bolt that did not come out of the back.
The main 13 bolts for the pan where torqued to 18 lb-ft and the 2 end bolts that go into the crankshaft cover where torqued to 9 lb-ft or 106 in-lb.
There it is all done.
and just incase anyone wants to see where I got my info from here is the link.
http://www.gmhightechperformance.com...ne_covers.html
Old 04-25-2011, 09:24 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
Nice project, I really like the motor. Please let us know how the oil pan looks in the car. If it hangs down below the frame crossmember. I have been waiting to see one installed. Is the overall height of the pan at the drain plug 5.75"?
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 04-26-2011, 07:43 AM
I will grab some pictures. I might mess with trying to put it in for a dry fit tonight if I can find some time. I would say that the overall is right around 5.75"
