Go Back   Lateral-g Forums > Vendor Specific Technical Discussions and Support > Roadster Shop Chassis and Components
Old 05-09-2011, 08:17 PM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
Originally Posted by no bags View Post
..............................too nice to put a body on that work of art!
Thanks... we were debating running just a roll cage and a seat (no body) for a demo car.
www.roadstershop.com
Old 05-09-2011, 09:53 PM
olds87 olds87 is offline
Have any one came to you for making a chassis for a g-body car?
James W.
1987 Oldsmobile
Cutlass Supreme
Old 05-10-2011, 09:22 AM
Supporting Vendor
RoadsterShop.com
We have had several people ask about a G body chassis, but haven't had anyone seriously step up to the plate yet. If you are interested, we can build you one as a custom chassis.
Old 05-10-2011, 11:04 AM
DemonSRT8 DemonSRT8 is offline
Can you describe the details on the Mopar E body chassis please?
Is the design like the Schwartz chassis where the body sits on the frame with minor cutting of the unibody?
Photos would be nice!
Beautiful pieces.
thanks
Darren
Old 05-10-2011, 07:17 PM
If I had the money, I will be all over it.
James W.
1987 Oldsmobile
Cutlass Supreme
Old 05-10-2011, 09:02 PM
Van B's Avatar
Van B Van B is offline
You need a 1st gen Camaro for a guinea pig? Maybe we can work something out After all, I am only about 45 minutes up the road...
Jeff
99 Miata LS6
67 Camaro Street Fighter 599 HP L92-SOLD
Old 05-11-2011, 09:57 AM
Supporting Vendor
RoadsterShop.com
Beautiful pieces.
thanks
Darren
Thanks. We are just finishing 2 chassis for 70 Challengers right now. I will start a new thread on them next week when they are completed. It is a true full chassis design, unlike others that you have mentioned. We did not see that you could gain any additional strength going that route. It also leaves the car sitting rather high for our liking. Our chassis will require cutting the passenger floor out of the car, but we have deigned an angled inside frame rail and dropped center crossmember that allows you to build a drop floor in the car since these are tight on head room.
Old 05-11-2011, 09:59 AM
Supporting Vendor
RoadsterShop.com
Van, tempting.... but we are gonna have to pass. We currently have a 69 in the shop tht we are starting a full build for a local customer using this set up, and we will be building a 70 very shortly.
Old 05-25-2011, 05:23 AM
eliterides's Avatar
eliterides eliterides is offline
Default Irs
Great looking setup, any pricing worked out yet.
I'de like to run the IRS in one of your Fast Track frames to suit Gen 1 68 Camaro.
Any ideas on how much metal work will need to be done in the rear seat and trunk area.
Great work as always.
John
Old 05-28-2011, 02:46 PM
Supporting Vendor
RoadsterShop.com
Thanks John!
On the Chevelle, all that was needed was to extend the section of the floor above the rear end back a few inches before dropping off to form the trunk well. It appears that a Camaro will need the same modification.
This was a pretty simple sheet metal filler piece we made. The additional room is actually only needed for frame rail clearance.
