06-04-2011, 08:49 PM
Another 69 Camaro
I will post pictures tomorrow.. 4 speed, 396 10 bolt soon to be...
Doe's any one know were I can get some 20"spinners and a few gallons of chameleon paint?
Just kidding....
DSE Mini tube, 12 bolt, DSE control arms, LS ??? with a T56
I want 500 hp, 5 speed, Air and 25 mpg. 13 in bear brakes, dropped with the biggest meat's i can get under the rear. Frame rails will be notched... Im thinking of the new dodge challenger gun metal gray with matt finish over the cowl? Or house of color Sun set pearl.. Color of my 67 with a matt finish on the hood.
Kirk
67 Convertible LS7 BBC 542HP.540 TQ
400 Turbo, 12 bolt posi, 13"12'' CPP Disc, Hotchkis connectors, belly pan.. Hush matt. 3" mandrel bent and load of other stuff.. More a show an Go..
07-06-2011, 08:24 AM
DSE order
Boze lateral-g wheels 18-12, 18 -8
BFG KDW 335-30ZR -18 rear, 245-40ZR-18
DSE #3 speed front suspension package,
DSE Upper-Lower control arms,
DSE close ratio gear box
DSE steering rebuild kit
QA-1 Coil over kit.
DSE rag joint,
DSE front sway Bar,
DSE brake boaster
Bear portioning valve.
DSE sub frame connectors
DSE deep tub
DSE 12 bolt rear, 411 true trac,
DSE 1340 Yoke
DSE rear cover
DSE 2"dropped springs
DSE shock re locator.
DSE QA-1 rear shocks
DSE spring re locator
Hotchkis rear sway bar system
I have Cal Tracks, I don't know if I'm going to run them,
Also bought Bear 13'' brake. 2 piston front and rear that will be up for sale.
I'm going to do suspension, rear end.
Next winter will be motor and trans.
Its going to be 3-7 year project
Kirk
07-06-2011, 10:02 AM
That is a nice list of goodies from DSE!
I am looking forward to watching you put it all together.
Eric
07-19-2011, 09:48 PM
Thanks Eric. All the DSE parts came today, Right now I've named the car
BOOGER.... I'm not sure what color Im painting it yet. All I no is it is not staying green.
Kirk
Kirk
07-15-2011, 07:08 AM
DSE products shipped
I got my shipping confirmation from UPS saying DSE shipped 11 boxes 241 lbs, and bear dropped shipped there parts, I did for get 2 things, so I emailed Paul, and got them on the way, Now I just need to buy a left and a new set off good ribs so I can move without pain  I ordered my Boze wheels 2 weeks ago so hopefully by the time I get tubs done and the rest of the suspension stuff in, the wheels ail show up.
does anyone have maxlift?
Kirk
07-16-2011, 12:59 PM
Christmas in July!
Sounds like you are well on your way, Kirk!
07-19-2011, 09:41 PM
All my DSE Suspension parts came today, Friday I pick up a rotisserie for the car, I'm still waiting on Brakes to show up and the Mosier rear end. The Boze lateral G wheels should be here in 3 weeks. Tear down starts on Saturday
My plan is to tear front clip off and get subframe blasted? I might sand it.
Work on install of front coil over kit. While it's getting powder coated,
I will get car on rotisserie and start mini tub.
It just so happens that a mechanic friend is slow at his shop so I might get some help.
Wish me luck,I went back to Doc today and the sent me in for xrays again on my ribs. Dam things are still sore
Kirk
06-06-2011, 02:22 PM
Good luck with your build. Gonna be nice.
Yes, DSE are good folk. They run a great business. Top notch customer service.
06-06-2011, 02:38 PM
Pictures added
Kirk
Reason: added caption
06-07-2011, 05:18 AM
Looks like the perfect victim, Kirk.
