Old 10-31-2011, 02:30 PM
BBC69Camaro's Avatar
If you want to get aluminum really clean you could maybe find a local machine shop with a Jet clean machine. That worked well for getting aluminum heads and blocks degreased and really clean.
Old 10-31-2011, 06:28 PM
64skylarkls1 64skylarkls1 is offline
Thanks guys but I know there was a spray acid I used on my aluminum slotted wheels on my first car wayyyyyyyyyyyyyyyyy too many years ago. It really brightened the aluminum then I would polish it. Something like that would work out just fine, I'm just not sure what the spray was. I really don't want to take the motor anywhere and I don't want to paint it either. Somebody must know what they spray is.
Thanks again.
Old 12-13-2011, 10:20 AM
Default A follow up
Well I got'r done.
I used simple green to remove the most of the dirt and grease which worked very well. Then I followed with a dupont degreaser that was safe for a leaving a paintable surface.
There was more staining and discoloration than I liked so I used duplicolor 500 degree primer, cast aluminum paint and clearcoat. It turned out great. I did some test pieces with the "aluminum" color but did not like how bright it was. The "cast aluminum" seemed to be the right shade. The Dupli-color rattle can spray nozzles are very user friendly and the stuff flashes fast, ten minutes between coats. All coats have to be applied within the same hour for proper curing, I was pleased with the product.
It will be some time before the car see's the road but I hope this stuff stays on good. Thanks to all who replied
Old 12-13-2011, 11:25 AM
ccracin's Avatar
ccracin ccracin is offline
Originally Posted by 64skylarkls1 View Post
Well I got'r done.
Can you post some pics? Interested in the look. Thanks.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 12-13-2011, 03:37 PM
Default Pics
Here you go!
Old 03-24-2012, 06:27 PM
DETON8R's Avatar
DETON8R DETON8R is offline
Here you go!
Looks good!! I may be doing that here in the near future, but I need to rebuild my engine first.
DETONATOR - 69 Camaro RS
Old 04-03-2012, 03:32 PM
bobcat68rs bobcat68rs is offline
Default clear
Should the shinny/machined surface's be scuffed? maybe with a red scotch brite?
Old 12-13-2011, 11:55 PM
makoshark makoshark is offline
Thanks again.
That spray is Eagle One Mag Wheel Cleaner. You can find it at pretty much any local auto parts stores.
Old 03-18-2012, 01:29 PM
onelapduster onelapduster is offline
diggin from the dead, but I wanted to say thanks for posting pictures, that really turned out great. Ive got an LSx and a 32V mod motor that will benefit from this!
Old 03-19-2012, 05:51 PM
Thanks for the compliment and I'm glad the pics were helpful. I can't say how well it will stand up because I still haven't made it to the road!!! Does anybody else have the problem of their projects growing in size as you work on them?!
Gene
