Old 03-10-2006, 12:08 AM
zbugger's Avatar
zbugger zbugger is offline
Default Crossram intake on ebay
Anyone else see this one? http://cgi.ebay.com/ebaymotors/ws/eB...ALCA%3AUS%3A31
Old 03-10-2006, 05:22 AM
almcbri's Avatar
almcbri almcbri is offline
those things are insane. I remeber a few months back one went for 12K or something.
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 03-10-2006, 05:30 AM
Steve Chryssos's Avatar
I tried so hard to get my Offy cross-ram to work across the entire rpm band. I even switched to a pair of Holley 8007 390cfm vacuum secondary Pinto carbs to try and boost the signal and isolate secondary opening function.
But no matter what I tried, the intake would work well in one part of the rev range, but not across the board. The one thing I never tried was throttle body injection. But ultimately, I think as a wet flow design, that intake manifold just does not work on the street. And it's not really feasible to mount direct port injector nozzles unless you could somehow come up from the bottom.
I'm sorry. Is that too much information?
It's cool looking and it's rare.
________________
Steve Chryssos
Ridetech.com
Old 03-10-2006, 09:44 AM
race-rodz race-rodz is offline
back when i had my 69 Z/28 (11 years ago) i used to see gm x-rams at swap meets goin for 1500, i guess i shoulda been buyin all i could.
Old 03-11-2006, 07:12 PM
rocketman's Avatar
hell i think i have one,guess it maybe a good time sell.
Old 03-11-2006, 09:30 PM
He's on the first gen board. Paid $100 for it from a wrecking yard and about $500 for Mc Neish to restore it. Think he did well!
Old 03-11-2006, 09:35 PM
BC69's Avatar
BC69 BC69 is offline
Weren't there a couple Ebay auctions with some cross-ram setups going for 20k? It was a while ago, but I thought thats what the number was.
Tim
In memory of those gone before us
In gratitude for those who care.
Old 03-12-2006, 11:34 AM
Diognes56's Avatar
Diognes56 Diognes56 is offline
Holy Cow!!! I could have the engine/tranny/rear end that I want for what the current bid on that intake is!!!
David
Old 03-12-2006, 02:00 PM
rocketrod rocketrod is offline
Tim
I saw one go for almost $24,000 last year on eBay
Old 03-12-2006, 02:55 PM
Silverback's Avatar
Silverback Silverback is offline
Holy cow… I know of one that went for less then $400 a couple of months ago
I’ve done a ton of screwing around with the early 80’s crossfire setup (basically same design with smaller runners) and always loved it… much better power production across the power band then most comparable setups once you figure out how to work around it’s limitations. I like it so much that I’m converting my full size truck to use one.
Donno, if you think outside the box and turn it into a semi wet flow setup you could get around it’s limitations and have some interesting advantages. I’d move the injectors to the lid right at the runner openings, that way you can use the cooling/detonation control/mixture advantages of wet flow with the delivery and control advantages of dry flow and fix any possible puddling issues that you get with with TBI/carbs
