Old 01-29-2012, 09:43 AM
Blake Foster's Avatar
Originally Posted by JSM View Post
Does this mean that if you did have a current rear set-up (like few guys have stated) that you could not just simply cut off your "ends" and retro-fit with your kit anyway, because basically you would end up with a narrower Wheel Mount Surface?
Of course this would mostly affect guys with existing wheel/tire packages. Am I reading correctly?
I Will start with this one.
That is how it appears from the drawings and numbers we have been working with. UNTILL we actually try one and see if it can be done i will not have a solid answer on that. Keep in mind the intent was to sell Complete units as it has never been a "Retrofit" so we need to do more work on that if we are going to go down that road. I will keep everyone posted.
Blake Foster
www.speedtechperformance.com
