Old 02-01-2012, 08:40 PM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
Default 1963 Fairlane at the Roadster Shop
This is a pretty unique project that we are building for a repeat customer. He likes cars that are out of the norm, but definitely cool in their uniqueness. We are just getting underway with the latest, a 1963 Fairlane. The car will be built to look completely stock and give it a total grandma/sleeper look. Underneath the car will be a custom fully independent Fast Track chassis. Power is coming from a Jon Kaase Boss 9 motor with a Tremec 6-speed.
As the car showed up:
After removing the coils we played with a lot of ride heights until we got one that the owner was happy with. (the version that we were happy with was abut 4 inches lower! As the owner put it, "if it was up to you young guys every car would be so low you couldn't drive it")
www.roadstershop.com
Old 02-01-2012, 08:44 PM
Supporting Vendor
RoadsterShop.com
The car was disassembled and the chassis was designed and built for the car with our Fast Track IFS and IRS
Test fitting the body on the chassis before it gets sent out to be media blasted.
Old 02-01-2012, 08:49 PM
Supporting Vendor
RoadsterShop.com
The body came back from media blaster with all kinds of surprises!
A shot down into the bottom of the quarter revealed some real "custom" work. A true "specialist" must have been the one to originally restore this car. The bottom of the quarter was "constructed" from cardboard, spray foam, wire mesh, and a whole lot of bondo!
Old 02-01-2012, 08:56 PM
Supporting Vendor
RoadsterShop.com
Beginning of the sheetmetal work. Since Fairlanes aren't all that popular, there literally isn't a single sheet metal replacement panel available. So everything had to be fabbed from scratch.
Old 02-01-2012, 08:58 PM
Supporting Vendor
RoadsterShop.com
And then this showed up....
Old 02-01-2012, 09:01 PM
KPC67's Avatar
KPC67 KPC67 is offline
Cool project! you guys are waaay to good!
Kevin Carter
Old 02-01-2012, 09:24 PM
mrr1999's Avatar
mrr1999 mrr1999 is offline
That motor is freakin' awesome! Going to be a great build
Mike - Las Vegas, NV
69 Camaro - in process
70 Chevelle SS396
69 Mach I
Yes...Chevys and Fords
Old 02-01-2012, 09:25 PM
caper150's Avatar
caper150 caper150 is offline
__________________________________
Darryl
My projects
1965 Ford Galaxie Big Block and 4Doors Project HULK
1966 Ford Galaxie 2 Door Sedan Project unnamed 4.6L Crown Vic runnig gear
Old 02-01-2012, 09:27 PM
strtcar strtcar is offline
Awesome, can't wait to see more.
Old 02-01-2012, 10:28 PM
Van B's Avatar
Van B Van B is offline
Not a Ford guy, but damn that's sexy.
Jeff
99 Miata LS6
67 Camaro Street Fighter 599 HP L92-SOLD
