Old 12-05-2011, 07:01 PM
jh99 jh99 is offline
Default 1967 Nova is On Track!!!
I have started my project again, and I have decided on a new route.
I know this is similar to Project Getaway but I have done almost all of the work. They had some awesome ideas though!!!
Chassisworks front clip- altered the ride height so the car sits 2.5" lower
Chassisworks canted 4-bar
Custom roll cage and sheetmetal
Turnkey Engines LS3
T56 6 speed
Luxury ID wheels and Nitto INVO tires-19x12 with 345/30R19
18x8 with 225/45R18
Some of these pics are hard to see. I am not sure why some of them are clear and some are not.
The next updates will be the stretching of the rear wheel openings (not sure how much I am going yet???) and the roll cage followed by the sheetmetal
Where it started
All of the undercoating
Now its clean
You can see where the clip was raised in the car
Rear clip welded into place
This is where the rear clip was tied into the frame
Old 12-06-2011, 05:12 PM
Here is the car at ride height. The front rocker is 5" and the rear is 5.75." I will have a little room to play with the adjustability of the rear shock mounts.
Any suggestions on how much rake?
Old 12-06-2011, 05:53 PM
coolwelder62's Avatar
Very,Very Cool.
Old 12-06-2011, 07:44 PM
youthpastor's Avatar
perfect! nice project-
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
Old 12-06-2011, 09:14 PM
56pickup's Avatar
56pickup 56pickup is offline
Looks Great! Nice Project!
Tyler
Old 12-07-2011, 03:20 AM
nice work...i like a 1" rake however...66-67's have funky wheel well openings so a 0- 3/4" would translate better.
Old 12-07-2011, 07:27 AM
wiedemab's Avatar
wiedemab wiedemab is offline
Default Nice Project!
Subscribed!
I have to ask -- tell me about your frame table... I will be looking to build one at some point and just like to hear the reasoning behind how people built theirs and the pros/cons etc..
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 12-07-2011, 04:52 PM
Originally Posted by wiedemab View Post
Subscribed!
Thanks! My I-beam you can see on the frame table is 15inch. There are three, 8inch I-beam running perpindicular to the 15inch you can see in the pic. I had to build some braces to the top plate for strenght. Three pieces was not enough. Then it has a piece of 1/2" plate that covers the entire table.
The table needs to be as solid as possible where there is no deflection. The more braces in the center the better.
If i had to do it again, I would have the 15" on the bottom still, but put the 8" on top of the 15" every couple of feet. Then plate the top. Hope this helps.
Hope this helps.
Old 02-10-2012, 03:24 PM
69c4x11's Avatar
69c4x11 69c4x11 is offline
Default Luv-it !
Jeremy,,Dude, You have gone this far with your skills don't be afraid to carry it past the point of no return,!! When I seen Eddie's car in super chevy I went to hunting a candidate, Sold my 66 Vette, paid off the house, and now I'mbuilding it at a snails pace,, "You Can Do It", cut it the way the General should have to begin with !!
Old 02-13-2012, 07:25 PM
Here are a few updates. The rear quarters have been stretched, have the block and transmission mocked up, and started to sheet metal the tunnel.
Stretched rear quarters
Start of the trans tunnel
Exhaust cutouts and some views of the bottom
Hoping to have more done in the next week or so. Next is the firewall, then the rest of the tunnel.
