Old 02-26-2012, 11:38 AM
Some ECU's have this capability - some do not (running two fans). If not - you can control two fans with the SPAL PWM controller or similar. I like the SPAL version - it is easy to use - water proof - and with the addition of one relay will run twin fans. I like it's strategy of running the fans for awhile after turning off the A/C for a cool down period etc.
I know the FAST EFI has dual fan control... as did my Accel Gen 7 ECU
Old 02-26-2012, 09:37 PM
JustinB's Avatar
JustinB JustinB is offline
Greg, where are you finding the Spal Pwm controllers? From what I have been told Spal is no longer making them and I can't anybody who has some on the shelf.
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
Old 02-26-2012, 11:06 PM
Well -- It's been a couple years since I had to buy one... and the place I bought it from (I have two of them) also shows "no longer available".
Sad - it was a nice piece!
Old 02-27-2012, 10:51 AM
ironworks's Avatar
I sell quite a few of the Autorad units. There quality looks like something we might try and build. the PRC units look like miter cut projects with exposed welds. If I'm going to buy something that we use on one of our builds I want it to be as good as we would build or better. The Autorad Unit is really nice quality, all welds are sanded smooth and drilled and taped holes make things clean. AutoRad's radiators are bigger in most cases.
We sometimes run the fan circuit off the ECU or Ron Francis makes a really nice Controller also. It is fully adjustable and uses a wire lead that can hook anywhere to the block. It requires more knowledge to set up as far as a tem gun, But is really clean and does not use a thermostat sender. Just an Eyelet hooked to a bolt on the cylinder head.
The other hard part about the ECU fan signal is getting the AC to work with that properly. The external fan switches address that more easily.
Old 02-28-2012, 04:16 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
There are a couple on ebay.
Old 02-28-2012, 07:24 AM
ironworks's Avatar
These work awesome. I sell a bunch of them.
http://www.ronfrancis.com/prodinfo.asp?number=AR-88
Old 02-28-2012, 07:47 AM
I just liked the way the SPAL PWM would run fan #1 at half speed and then ramp up as needed... and would run the fans on cool down mode after running the A/C... and that it was waterproof so you had lots of mounting choices.
But obviously that's a mute point now.
Old 02-28-2012, 08:00 AM
There will be TWO less SPAL PWM controllers on Ebay.... I'm bidding on both of them.
EEEEEEEHHHHHHHAAAAAAAAAA
Old 02-29-2012, 10:12 AM
KPC67's Avatar
KPC67 KPC67 is offline
Greg, you beat me to it
Its probably best not to start a bidding war with you!... Your pockets are deeper.
Kevin Carter
Old 02-29-2012, 10:51 AM
Ron in SoCal's Avatar
Yeah, but you could shill-bid and drive up the price...
Ron in SoCal
69 Camaro in progress
