04-26-2012, 10:39 PM
Anyone running solid mounts?
I finally found some 2" setback plates but they are solid (well they have the poly ones but they sit the motor too high)
Am I going to regret going solid mounts on a twin turbo wild cam car?
http://dirtydingo.com/store/Muscle-C...306/index.html
[SIGPIC][/SIGPIC]
04-27-2012, 08:43 PM
I have solid mounts on my turbo LS and didn't notice any increase in vibration. I do have a mild cam though...
67 Camaro. LQ4/T56 w/Precision 7675 turbo.
04-28-2012, 06:38 AM
It is my understanding that solid mounts will cause false hits on your knock sensors.
04-28-2012, 10:31 AM
I'm running solid mounts as well. I didn't notice much of a difference either. Also, make sure you run a poly trans mount I have heard you can crack the tranny case tailshaft if you run all solid.
04-28-2012, 12:40 PM
Thanks guys. Ill try the solid.
By using the solid I get that extra 1/4" drop down on my motor. I really need that so my manifold clears the hood.
[SIGPIC][/SIGPIC]
04-28-2012, 12:52 PM
With twin turbos, I really think you will need solid mounts. Poly or Rubber will give way eventually.
04-28-2012, 07:36 PM
Question for my general knowledge...aren't you stressing the block by running solid mounts? I thought you wanted the motor to be able to "flex" or have some amount of movement. I've heard of a lot of sprint blocks cracking due to solid motor mounts.
04-29-2012, 04:54 PM
I heard the same thing.
04-29-2012, 10:34 PM
Maybe run a solid on the drivers side and poly on the passenger side? I have a solid on the drivers side and rubber on the passenger and the engine moves to much for my taste.
05-01-2012, 04:44 AM
What if you had either a front or mid engine plate that had poly mounts at the frame mounting points? This would significantly decrease the moment and still provide dampening.
