Old 06-20-2012, 04:01 PM
Musclerodz's Avatar
Originally Posted by Roadster Shop View Post
A few more updates on the C-10 now that it is just about wrapped up.
Out with the old.....
In with the new... Turn key Engines 585 HP LS3 and TKO-600. And a little bit of tire in there as well!
New Speedway mod Lite floater with Wilwood 13" brakes.
Mini-tubbed the bed to get the wider tires int eh back and then finally got around to bed lining it for a nice clean finish.
345/30R19's on Forgeline's on the front. Full turning radius, no modifications to the body or suspension, and 13.8" of rubber on each side!
A nice comparison of the original front tires and the new front tires.
I am in love. What do you plan to do about inner fenders? I am guessing it will be at Columbus as well?
Mike Redpath
Musclerodz & Customz
facebook page
Old 06-20-2012, 05:03 PM
tones2SS's Avatar
tones2SS tones2SS is offline
What bed liner did you guys use? Looks very clean!
Old 06-20-2012, 05:07 PM
coolwelder62's Avatar
I am really diggin the C-10.
Old 06-20-2012, 05:26 PM
Rick D's Avatar
Rick D Rick D is offline
Man that is some front tire on that bad boy! So what are the plans for the trans that came out of the truck??
Rick
Old 06-20-2012, 08:05 PM
boonedog boonedog is offline
In with the new... Turn Key Engines 585 HP LS3 and TKO-600. And a little bit of tire in there as well!
New Speedway Mod Lite floater with Wilwood 13" brakes.
WOW! love everything about this truck
Old 06-20-2012, 08:44 PM
WILWAXU WILWAXU is offline
AWESOME!
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 06-20-2012, 09:08 PM
killer67's Avatar
killer67 killer67 is offline
Amazing! Getting 14" of rubber to turn in the front is quite an achievement
Old 06-21-2012, 08:38 AM
carbuff's Avatar
carbuff carbuff is offline
What are you using for a steering rack? With that much front rubber, so you have to update the rack or pump or anything to make it comparably drivable?
Love the truck!
Old 06-21-2012, 11:49 AM
Jr's Avatar
Jr Jr is offline
I see you have a cooler in front of the radiator...what is the cooler hooked up to? Oil, trans, ps?
Old 06-21-2012, 12:54 PM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
The truck will be at Columbus and running in the Autocross Sponsor Shoot Out. No plans yet for inner fenders. Probably run the truck with out them for a while. If we get time we will fab something up for it.
Thanks, we use Rhino Liner
No plans just yet. Probably use it in something else down the line. We have enough shop projects that I'm sure it will find a home shortly.
Love the truck!
We were a little worried about the drivability with that big of front tire on the truck. We changed the power steering pulley to get a more out of the pump. Under tight slalom situations, there was a slight lag in the power steering. The pulley change took care of that. Otherwise you can't tell the difference between the 255's that were on there before. Steering feel is the same. We drove the truck 90 miles to Blackhawk Raceway yesterday and then put 50+ hard track laps on it. Steering feels great and the truck sticks like crazy!
It is a power steering cooler.
www.roadstershop.com
