Old 06-28-2012, 08:06 PM
PhillySpeedNYC PhillySpeedNYC is offline
Default Anyone post photos of where and how you mounted your remote PS Reservoirs?
Just got my PSC Reservoir the other day for my Hydratech kit but i have not dropped it off at the shop yet as i am still waiting on my KRC pump and other stuff.
the Reservoir is much larger than I expected and I have no idea where I will mount it.
I am looking for mounting ideas so anyone if you can post some photos up for me to check out.
Old 06-29-2012, 12:31 AM
I had the PSC unit on my previous 68 mounted here. Kinda tight but yes it's a big piece.
Old 06-29-2012, 04:51 AM
hmm by the radiator would work but my washer box and radiator overflow res is there.
what type of hoses and fittings did you use on yours? Are those the push on style?
Old 06-29-2012, 09:55 AM
slenning's Avatar
slenning slenning is offline
I've got mine mounted in the exact same spot as Flash's pic
Steve
70 Camaro - in process https://lateral-g.net/forums/showthread.php4?t=50636
69 Camaro LS7/T56 https://lateral-g.net/members/lenning/
69 Camaro SS396/350hp
64 Chevelle - patiently waiting
2014 Z28 Ashen Gray
2010 Camaro 2SS/RS Black w/White stripes (wife's car)
2015 SS (the 4 door one) Wife's other car
Old 06-29-2012, 11:34 AM
Lenie's Avatar
Lenie Lenie is offline
^^same here.
Lenie
Old 07-01-2012, 07:58 PM
guys would mounting it by the radiator support be the ideal location i specifically heard the pump res much be higher than the pump itself and the line must be less than 16 inches long. this is why i wanted to keep my pump and res close to one another as well as i do not need any more problems than i already have.
